Hey guys. Just got around to installing my HDi EBC-R. I found a hole through the firewall for the hoses and cables and tee'd the boost line from the unit onto a hose coming off the intake manifold, but I'm a bit confused as to one of the solenoid connections.
The instructions say one end is to be connected to the wastegate actuator and the other end to the turbo. I found the actuator hose fine, but just not quite sure which hose comes off the turbocharger. I did some research and found some people connect it to the intercooler piping instead? Would that be alright for this case? I'm running the stock SMIC on an R34 GTT. Also, does anyone know what the top hose on the standard solenoid goes to? I traced it to a gold pipe with a bend in it located under the intercooler piping but not sure as to what it actually is/does.
At the moment, the stock solenoid looks like so with 2 hoses coming out, one of them tee'd:
_____
l l________
l _________ ???
l l
l l wastegate actuator
l l ________l l_____
stock solenoid l _______________ intercooler
l l
l l
l l
___l l___
So I guess my question is, instead of connecting the new solenoid to the turbocharger, would it be okay to connect it to the intercooler piping like some people have in other boost controller install guides? And also, what would I do with the top hose coming out of the stock solenoid? Block it off? Any help would be greatly appreciated! :P
Block off everything on the stock boost solenoid. Unplugging it might bring up an error code though so I wont tell you to unplug it, you can experiment with that lol.
If you have 1 side of the ebc solenoid hooked up to the actuator thats fine. Other side needs a pressure source, this can be off the compressor housing (u dont have one so pass...) you should have a nipple comming off an intercooler pipe or worst case get a T piece and T off the big vacuum line that goes to ur carbon canister and make that go straight to the solenoid on the port that requres a pressure source. There should be a pressure source somewhere in that area though.
Heres a pic of a greddy profec b spec 2 install diagram, will be same principle.
  • 2 years later...
