HALLOWEEN: Dyno Day / Fundraiser
Ok, so it's been a while since we had a decent dyno day... To be exact the last dyno day we had was 12th February 2009, not long after the horrific bush-fires that destroys so many lives and homes. Why haven't we had one since? Honestly it was pretty exhausting with the turnout we had - 75 cars in 8 hours non stop, a great atmosphere, and $2820 was raised and donated to the Red Cross Bushfire Appeal!
It's been bugging me a while, and the time is due... In my life I've seen people had their lives cut short by many different causes, and also seen some great triumphs over adversity... One charity I would like to help out this time is The Australian Cancer Research Foundation (ACRF) - We will be donating our time and facilities, and ask you take advantage of the offer to dyno your vehicle of choice in the name of charity!
Dr Drift ACRF Halloween Dyno Day & Night - Sunday 31st October 2010
Unit 5 / 9 Alick Rd
Tottenham, Victoria
Australia, 3012
Time: 3pm till late
Date : Sunday 31st October 2010
Price : $50 per car / $30 per anything else - Donated to the Australian Cancer Research Foundation
It does not matter if you have a 5 kw car or a 500 kw car its all in the name of charity so if your car is not running bring your mums magna down for a run.!
All other donations are welcome & encouraged.
Clapped out commos, shit boxes, rollers, lambos, whatever... Mop on hand to clean mess!
Anyone know a butcher to donate some meat for a BBQ we can raise some funds with that too?
We can and will dyno motorbikes, electric wheel chairs, pit bikes, pocket bikes, ride on law mowers.. whatever you've got... I DARE YOU!
  • Replies 45
Posted Images
Would be there in a flash Dr Drfit if I didnt have a flight to catch at 7pm Sunday night.
Good luck and congrats on choosing the ACRF as Im sure nearly every member has been affected by this disease in some way!!
Hope you get the support a day like this deserves!!
Ash - drop the front shaft before you come down, no excuses.
Thanks for the support guys. last time we kicked $2800 into the bushfire appeals fund at Red Cross!
Sam
Sam
I'd be coming straight from the Mt Buller cruise lol, somewhat a problem as i'll be needing my front shaft well attached for that one :)
I;m tempted to bring my bike along.
I don't think it's got the HP that it should have, so would be good to get a clearer idea. But then I'd like to know why the Skyline is putting out, too.
Great Job Sam! I would bring the wifes Familia GTX if it was not clutchless this weekend on a hoist.
Dont have the Black R32 GTS4 anymore as you might remember. I think the new owner Anton may have had you dyno it though after he did some work to it? Catch you around sometime, thanks for all the great work.... Regards, Greg.
Hey guys
My partner is thinking about taking his FTO down for the day, and he was wondering whether there'd be any nice cars there :P
His FTO has minimal engine mods but he's interested to know what it'd get....are they doing anything else as well as the dyno?? It'd be great to do a Db test on his sound system
That's awesome that you guys raised so much for the bushfires, the red cross was a serious life saver during the fires, they took care packages around to everyone, and got some people I know back on their feet. We only lost our front lawn, but they still offered help getting our place cleaned up.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
