Almost 2 weeks ago I had my GTR boot badge ripped off by some drop kick(s) so I am interested in putting on a new one maybe a R35 kind.
I have seen a few variations like the r35 and some from older models as well: http://www.rhdjapan.com/nissan/r35-gt-r/oe...t-rebuild-parts . I have spotted a gtr badge with all letters displayed all horizontally. post-60042-1288047944_thumb.jpg I think that this would look great just above the right rear taillight on the boot lid, then it would be on the exact opposite side to the Nissan badge that is above the left side taillights.
What model is this badge from in the above picture?
The KPGC10 GTR badge would be bolted on, but whats some advice on how to keep the others on really well?
Please keep an eye out for my old badge, the "r" colour is a very dark pink.
cheers all
https://www.sau.com.au/forums/topic/341882-re-badge/
Just rip a GTR badge of and 32 or 33 GTS-T.
You will be doing them a favour and you get another GTR badge..
Hell, It might even be yours :P
yeah pretty funny if I could flog my back. Just it may cause a chain effect.
And great advice about keeping it all original.
So anyone wanna what model the badge is from in the above posted picture?
https://www.sau.com.au/forums/topic/341882-re-badge/#findComment-5519260
lol
*flog mine back.
And the one in the picture looks like a identical front to the original badge that I had.
arhhh :huh: I meant like the above picture of the GTR badge looks like a identical FONT to the original badge I had.
And yeah I am still wondering if that is a stock badge like of a r33 or r34 GTR I have never seen it before on a car, have any of you guys able to clarify that? Answers?
https://www.sau.com.au/forums/topic/341882-re-badge/#findComment-5523206
stick with the standard one IMO mate. surely they cant be that expensive from nissan? or can they? :ermm:
have not checked I am still concerning the options. But this link is a badge to replace mine, even with a grey back gound. http://www.rhdjapan.com/nissan-bnr32-skyli...lem-badge-50344
https://www.sau.com.au/forums/topic/341882-re-badge/#findComment-5524634
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
