I looked into actual 2860RS' (instead of the high flow I had), 2871s, 2876s, 3071s, T518zs, TD05s, TD06s, RX6s, etc etc etc ad nauseum, I now know more about those than I'll ever have the need to, while the 6258 may not be the best 'bang for buck' for most punters, for my dollar, it was the only way to go.
As you go along, can you kindly list items you have bought or modified in order to get it running well?
It would certainly benefit the whole community.
Sure thing. :)
The list so far,
Manifold (not strictly necessary)
Intake pipe
Outlet pipe
Dump pipe
Water fitting on the block (comp cover fouls it, yet to trial any solutions)
Oil drain line
So far that's it. I can't foresee any other issues aside from those. But I'll post them as they come.
4) The BP ratio should be intake pressure higher than exh pressure, until approx 5500rpm. from that point to redline, it should be 1:1
Geoff,
From reading around maximum is 2.5:1 ex/in pressure ratio. I have checked with the matchbot for both the 6255 and 6258, both exceed your 1:1, ratio. They are 1.6:1 and 1.5:1 pressure ratios, respectively. From talking to several tuners. This is optinum.
Ultimately I been trying to compare them to the GT2860r-5's, and if they fare well I will purchase a pair of EFRs.
I could use help by a dyno chart of either 6255 or 6258, and the boost graph included. This would help my decision matrix.
Thanks,
Joe
Edited by Sidwysracr
Sure thing. :)
The list so far,
Intake pipe
Outlet pipe
Dump pipe
Oil drain line
Is your motor built? If not, what is your expectation for things breaking down? Including your said manifold.
I may be running an SR soon and am out of touch with their capabilities.
Unopened. :)
I played with the idea of a simple rebuild while I was waiting, but knowing how things snowball, I decided against it to save my bank account.
Only internal modifications will be a set of BC step 2 cams. I'll likely go back to standard manifold, don't much like the design of the A'pexi.
Aiming for 250 on a nice safe E85 tune. Another 30 or so before I start worrying about the bottom end.
My only concern at this stage is the gearbox. I reckon I'll lunch that well before the motor shows signs of going to the scrap heap in the sky.
well I have some news. have a set of 6258s for a GTR on the way now. :) Full kit with full race manifolds, twin 6258s etc. This particular car has run -5s and -10s so it'll be a great comparison. I'm hoping for -10 power with -5 driveability.... I think they'll deliver but there's only one way to find out..... bear in mind they are quite a bit of airflow. 44lb each is a lot of powa for a little 2.6L engine.... :)
Keen to see results here
So twin high mounts? How 90's JDM of you Mr Baron!
lol. they should be awesome.
Consider this. look at the EFR range and consider the 9180 flows 94lb/min. a single 6258 flows 44lb/min I would say it's not unreasonable to expect them to produce 80lb/min combined in a twin GTR set-up. that's 800hp of air.
the car they are going on has run 2530s/-5s and made the usual 350kw or so. it's also run GTRS/-10s and made the usual 400+ kw but with typical surge down low that's a pig to drive through (even on the track).
I would like to think these will be close to the -10 power but with close to -5 response. I wouldn't be disappointed if they make a little less than the -10s but without the surge down low and with fat midrange.
I'm not sure if anyone else has bought a set from full race for a GTR apart from the one in the US they tested on. so this may be the first 'retail' set that goes out the door.
hope to have them arrive next week.
The other turbo I got from BW/FR is here and has already been pipped up etc and should be running very, very soon. it's the big boy 9180. another mate of mine has a 8374 coming soon so it'll be interesting to compare the 3. in power terms it goes 8374 then twin 6258 then single 9180. I'm keen to see if that's how it plays out in real life and what kind of power/response compromise we get. the only difference really is the 9180 is on a 3L the other 2 are both 2.6.
Unopened. :)
Awesome. I might 'boost it till it blows' with mine and see what comes about. Its been making 200odd @ 14pound since I built it in 03ish so it will be interesting to see how it likes more lol. Having a 4 pot again reopens my interest for the EFR, cant wait to see yours in action!
Also super keen to watch Beer Baron pioneer the SAU EFR stage!
Twin high mounts? what is JDM about that lol...
Think pre hype era, when a modified GTR was very much jap territory. Then think big twin kits... What was available back then? Some pretty ordinary garrett stuff and the ageless TD range.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
