Is there any likelyhood the EFR9180 will be replaced and tried out or has that been abandoned now that the old faithful Garrett based unit saved the day?
bloody oath mate. as soon as possible there will be a EFR9180 back on the Advan/Hi-Octane/RGM R34. Mark it about to try some other stuff (not turbo related) but as soon as we get another 9180 it's going back on for more testing. and we were all so happy with it's initial performance we are converting the RGM R32 to a full race manifold, twin turbosmart gates and a 9180 too.
the T04Z was ok but it was only ever 'plan C' and a last minute back-up option. it was used simply because Mark had it available (was on the R33), and would fit the existing full race manifold set-up most easily of the available options (2 days before the event we didn't have many other choices!).
It's full steam ahead with Full Race and Borg Warner EFR gear on both the RGM GTRs.
Awesome, looking forward to hearing how they both go - whenever the new units become available!
Mr Sub - ahh blargh, the nature of my work means that if I post during the day sometimes I engage autism mode. My bad :whistling:
Will the R32 still be a 2.6?
yes it will. :) there has been some serious heated debate over this one and to be honest (just don't tell anyone I said so) I can agree the logical/smart choice is to go 3L so it's the same as the R34 but the 2.6 option has some merit too and it's the way it's going.
as far as ancillaries etc go both cars will be almost identical though.
Tiny bit more progress.
Looking rather comfortable;
Had to clearance the mounting plate for the BCSV (which I won't be using...) slightly because it comes too close to the manifold.
And the banjo fitting solution for my water lines... Not so good.
Hard to see, but the outer edge and bolt for the recirc valve cover still hit the banjo bolt. Gonna head down to Pirtek and Enzed whenever I've got time and see if they can do anything for me. If I can't find a solution, it is safe to run these as oil cooled only... But I'd rather keep water cooling.
Only need to clock it a tiny bit more...
Plan was to have the outlet pointing straight down to avoid the water fitting problem and allow me to run the Pierburg, but there's the lines for the A/C and an engine mount in the way. It'll also require a pretty hard bend.
Probably largely irrelevant on a forum dominated by RB's, but you get that.
So what would one of the 6258 in single form be like on a 2L?
Ive read in a couple of places that an RB20 has similar character to an SR20, you may want to watch this thread to find out.
Correct me if Im wrong but it had been said in this thread that the 6258 is the turbo to have on an SR.
Based on what ive seen on a couple of other forums (cobalt and astra) I would probably be willing to go the 6758, there are also videos of a civic on youtube which absolutely hauls with one. The problem with all of those are that they are modern hicomp motors.. Kind of like the talk we had about VQ heads vs RB and the ridiculous flow differences.
Im still up in the air about new tech/old tech stuff... There is a good chance your better off leaving a TD on your ride :P But that civic on youtube is insane.. Instant gutfull of torque and delivery that doesnt just fry the tyres, MMMMMMM
Links? :)
No small pot-6 RB20 I've seen has turned a turbo as good as a big pot-4 SR20.
Would be interesting to see either way.
Not for the RB20, its'sorted and not touching it. But looking for a turbo for the 2L 4 in my Cossie as it rocks old school lag and as its a daily would be happy to lose some hp fof drivability. Runs a twin scroll manifold std, though not sure but think its T3.
Would having a small, say, 1/2 to one inch spacer made between the manifold and turbo housing help your clearance issue?
The EFR6258 and EFR6758 are T25 flange, or would you make up a manifold for it?
lithium, one benefit of the stainless steel housing is that it's a real pleasure to weld to.. if you wanted to run a t25 efr on a t3 manifold, properly weld a t3 flange on and port to suit
Edited by Full-Race Geoff
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
