Any idea on the cam/head specs on that 2j lith?
So full boost at 4k is rather good for a near 800hp
I wonder how much sooner the 6262 would come on?
The 2J is mental, its a 3.4litre stroker running an angry head and 9.5:1 compression - good motor to get the best out of a turbo.
Slightly OT, but from the same car the initial test was a PT6266 vs PT6766 vs a PT7175 - they just maxed out all turbos and posted the results:
SP have also tested a new PT6466CEA which the results for are flabberghasting. Looks like a fricken awesome unit for a street 3litre.
Naturally the power delivery and power levels are mental because of it being a big angry 2JZ - but its all relative. The EFR8374 is known to spool similar to a GT3582R, so the PT6266 etc are very very impressive for the power they make.
Stupidly responsive for the power output!
Yeah but have a look @ the power band, the EFR noses over after 1500rpm (4000-5500rpm), where the Precision pulls for a solid 2500rpm (5000-7500). Numbers are rough, but ya get the picture
Depends on the use of the car. Also Precision not being twin scroll as well... Very interesting comparo.
I assume it would be their 7 sec street/strip Supra motor for the big 1000hp runs
Was reading the full thread on SF earlier
We set out to prove the R14 conversion kit, ETS-Pro and EFR turbo today. using the EFR 8374 on my RB26, we got 1st place on the dyno - 704whp thru the cat, with huge area under the curve. This morning we also got 1st place in autocross (historically our worst event since we usually focused on drag and time attack) but a bad cyl #6 coilpack overheated in the back of the valley and ended our day. too bad, thats racing!
mr lith - here is a cell phone vid of the dyno pull from one of the guys who worked at the dyno shop, you can sort of see the chart at the end. the cat was glowing bright red
Edited by Full-Race Geoff
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
