My 6258 got pulled off the other day. Still in excellent condition after its first 17psi track outing. :)
Should have everything back together soon, then back on the dyno without an air leak... Hopefully.
Still looking good. :)
Turbine housing and exhaust manifold have both been ceramic coated, flange surfaces on the inlet manifold have been machined (3 of 4 were out of tolerance apparently), oil drain will be rectified next time I have a day off. Then I'll slap it back together, and it get back on the dyno, hopefully, with the mystery air leak sorted out.
Tha coating looks great. I'll do that on mine for sure.
I'm just REALLY frustrated about which one to get. "over-revving" these turbos seems to be a big no-no which sux because a 6258 looks ideal for awesome response on a 2.15L SR20 but even though I'm happy to run it down to 60% efficiency up near rev limiter, it's going beyond the "recommended" RPM. Not interested in th 6758 at all. It's compressor map looks horrible and the 7064's inducer is smaller anyway.
I just wish turbos were more customisable. I think the 70mm compressor model should also be offered with a 61mm turbine for smaller engines and a T3 divided .82 housing as well to fill the gap between the T25 .64 and the T4 divided .92/T3 .82 (both spool about the same).
What are the RPM limits on the EFR's?
That looks real clean. Who did the coating and what did it cost for the housing?
So get a 3071?
Anyway, i was at a track day recently and another s13 was out there with a .64 6758.
Basic built red top, 260/12mm camtechs, greddy intake manifold maybe and a high mount manifold. The thing was making a touch over 300rwkw at 21psi all in by 3500. Cheating with E85 but still very impressive.
I certainly wouldn't discount them.
So get a 3071?
3071R is bigger that a 7064. I want smaller. I'd use a 7064 over a 6758, even if I lost 150rpm of spool (which is all the dirrefence would be) in exchange for 10psi less exhaust manifold pressure and and extra 30kw up top. Makes for a way safer setup. It just annoys me that one must choose between a T25 .64 turbine housing and the next thing up is a T3 .82 with nothing in between. A T3 .82 divided housing for the 6258 through to 7670 would be just SO WINNING!
  • 3 weeks later...
E&H Motors in NZ have just released results of their testing with a twin scroll GTX3076R versus a twin scroll EFR7670 on their 2litre STI track car - worth noting that these results are not "all in", they have a stronger motor which will be used for that in future. From what the owner/tuner says it seems the EFR is much nicer to drive, and it sounds a bit like the EFR was seeming more eager to keep making more power.
Dyno plots:
I think it was just that they were aiming for an EFR7670 from the start, and ended up getting a GTX3076R to get going because of the huge waits for getting an EFR - or something to that effect. The test wasn't to because they were doing a shoot out, more just a result of having both turbos.
I know they've had a twin scroll GT3582R as well, I might see if they ever tried that on the Subaru....
Seems the EFR turbos don't need E85 to make good numbers - another Kiwi lad had his RB30DET R32 GTR tuned running a .92a/r twin scroll EFR8374 today on BP Ultimate, 462kw @ hubs on 20psi... full boost by 3300rpm.
Not too shabby!
Nice!
If only using one of these turbos was realistic. Waiting forever and having a questionable lifespan is very off putting.
Not that Id be at all interested anymore, owning a T3 6boost now -_-
Very nice! For the SR20? What trubro is going on it?
The life span of them don't seem to be a problem since the foundry change, I actually know of a few people using them - a 550whp STI I know has been using a 7670 lately with no issue, an EVO track car over here has also been using an EFR8374 and it has been performing excellently
Yeap for my SR. My DET block is down at the machinist right now, im waiting for a call to tell me what size slugs to order.
Having done as much reading as possible into readily available options I couldnt go past a simple TD06. The FP 73HTA wheel apparently needs a bit of energy to be turned and isnt likely to be as responsive as the old 20g item (more or less making it useless for me as I want 270-300kw). I also found a number of resources from people saying they had owned 3071 and TD06 SR's and found the TD06 to be a lot better matched.
So yeah, logical deduction lead me back to a simple kando TD06. $560 later and its crackin.
Sorry peeps, back to BW EFR :)
I wouldn't have (don't think I did) ever suggest the 73HTA for yours anyway - I reckon a 68HTA would have been great. I also lean towards TD06-20G vs GT3071R as well. Shame BW aren't doing EFR6758s in T3 though, I reckon one of those on an SR20 would be mental.
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
    • Or you mean the age old problem of early 2000's manual boost tees, where they never let the pressure out of the line between the boost tee, and the waste gate, so after your first trip on boost, the damn wastegate liked to stay open and be laggy on gear change?
    • Being behind an RB25DET, we know he won't have the small box for long at all...
