How do you guys running the EFR turbos find the boost recoveries between shifts compaired to similar turbos in the garrett range??
My EFR 7064 recovers from shifts around the same as a GT2871R. Pretty good considering the 2871 has a 54mm turbine wheel and the 7064 has a 64mm one.
Gotta love modern turbo tech - a 56lb/min turbo responding like a <45lb/min turbo... its a pretty sweet age when you can go for 25% more power and not loose any response :)
  • Like 1
Has anybody heard of any serious failures with these things in racing conditions? I mean like the behind the scenes kind of thing that doesn't get released till much later on.
In particular the 8374 turbo? Later on down the track were looking at possibly switching to this unit to replace our GT35r's that have been rebuilt god knows how many times.
I haven't seen many Indy Cars drop out this season with engine problems.....
Late getting back to this and Geoff Raicer in particular .<br />There are limits to what you can use on a standard exhaust manifold and I reckon if there were suitable TS IW T3 flanged turbos available the standard manifold mob would be better off .<br />I'm particular and I can't have everything as I'd like it even with a single scroll IW turbo . At the end of the day I probably need more cubes so I can have the stronger low down part throttle torque and less reliance on FI to do the job properly .<br />
For next time Geoff check this thread:
Will the .80 divided housings only be for B1 frame turbos or will they do it for the 7064 as well?
I'd be soooo keen for a little smaller housing on my 7064 to get full boost under 3000rpm :woot:
Brad is your 7064 mounted on a standard RB25 manifold and if so can we see some pics of it . It'd be interesting to see a bolt on one in an R33/34 engine bay .
Cheers A .
It's an SR20 with T4 TS.
Welcome to the thread.
I did look in your sig before I asked the question and wasn't going back a dozen pages to check what you run .
Does anyone here have a 7064 on an RB engine ?
Actually it was on page 61, this is page 64. Thus my commentary.
Most of our RB customers use the 8374. however there is a drift team in southern California "Animal Auto" using RB25 with EFR 7064. here is the motor setup:
Also on their FB page: https://www.facebook.com/AnimalAuto, check the vids from april 11 and may 21, the engine does not sound like most RB25's
I will ask - I do not know the answer to that one
Correct - in the last 2 years all Indycar teams are using off-the-shelf EFR6758 or EFR9180 and zero turbo failures to date
the 8374 is a really, really good turbo, my favorite turbo ive ever had on my RB26. If you are coming off a GT35R you will not be disappointed. We have this available as T3 or Twinscroll T4 IWG right now. (1.05 a/r still has a very long backorder )
  • 1 month later...
Here's a fun little clip (if anyone is familiar with the old High Octane DVDs the sensor of humour and style will be familiar - this is a little tongue in cheek) with an EFR7670 showing it's worth on an E85 fuelled EJ STi WRX: ("700hp" is actually ~450kw @ 4 hubs):
  • Like 2
  • 3 weeks later...
They don't do twins that small, EFR6258 shouldn't be far off in response but would make a crap load more power
Thank you ^_^
A single EFR7670 would however be more responsive and make more power than -9s
Not looking for top end , high 5's low 600 awhp and tears asphalt. Looking at cost for custom exhaust mani to keeping stock and having twins also ^_^ I want that balance instead of just gobs of power on top.
  • Like 1
Thank you ^_^
The single is smaller, more responsive than the twins. 6258 are capable of heaps
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
