Completely agree! For a vehicle like the skyline, an EFR is awesome, and I think you would be silly not to look seriously at one, WITH all the bits...
I just have issues trying to squeeze those extra 'bits' into my tiny east-west engine bay...
I dunno about you guys, but most turbo cars I see already have a more than suitable stock BOV.
Unfortunately they failed to make the intended splash onto the market, due to quite a few early failures, and it really doesn't matter the reason, people stepped back from them understandably. Garrett obviously tested their turbo's better, and decided not to release the Ti wheels just yet. I think they will be re-thinking that decision now.
Correct, most cars do run BOVs. But I believe its not only the fact you can save that money upgrading from stock, I think its the engineering behind it and how the recirculated airflow is designed to assist it keeping up shaft speed, when throttle plate is closed.
What failures?
Post people I talk to are staying away due to ugly design (I have heard that more times then not!), high cost, and no results. Not failures..?
Edited by Tonba
MHI got it going on and have for some time, a pair of TD05's of an EVO9 with Ti turbine wheels would be cool a reckon (which appropriate housings of course).
EFR on NA rb25 with E85....mmmmmmmmmmmmm..
mount it int he boot and even P-platers could get away with it ;)
You know shit is bad when a repost comes in the form of text.
Plenty of early shaft failures, and due to that it took months/years to supply some of the early orders and catch up with demand.
Have you even read this thread?
I keep hearing of failures, but I haven't seen any yet. I just wasn't sure..
Not the whole 89pages from the start... no I haven't.
Quite a few went bang when they were first released
Hmmm, interesting. Although a more then a few precisions have gone bang and people still seem to come back to them? Its not like BW are new players in the turbo game...
Oh, and I know a lot of FP turbos have done bang but people keep coming back!
Edited by Tonba
Those turbos are known to have problems.. Particularly with high shaft speeds, and antilag.
Edited by Tonba
The last EFR failure I have heard of in the last 18 months (I think?) was an EFR9180 which was pushed a little too hard and the turbine wheel let go, which imho isn't a problem with the turbo so much as something worth knowing about keeping in mind when working with a Titanium Alloy type turbine wheel.... they don't like being over spun hard, same applies to the TD05 TME wheels etc. Again, that turbo was being push well past the limit - not just a turbo being used to normal, or normal "pushing it a bit hard" type levels.
  • Like 2
I guess it comes back to the whole... 'why bother with the turbo speed sensor'. You need it because Ti turbine wheels are reknown for failure from overspeed.
It's been doing the rounds on Facebook the last week. It's a GT35 in the boot of a V8 soarer.
I have a funny feeling Scotty may know something about it ;)
If only it wasn't on that particular site, the amount of brainless retards replying gave me a headache. Hehe.
For RBs the EFRs are easily the best, they aren't particularly hard to fit big singles - not a lot more expensive considering the performance, and strong as anything... I find it weird that people have issues with the extra bits, they perform and save other bits of expense... especially if you are building a new setup. Not having to fabricate a place to fit a BOV, and buying the BOV in the first place definitely will save some coin and space and I don't mind the look of them, I reckon they look pretty serious business as opposed to yet another Garrett/Honeywell stamped compressor cover that could be anything from a T3/T4S up to a GTX3582R.
agreed ^^
This car had it's first drift outing with the EFR this weekend, running on it's lowest boost setting - here's some in car from the event: https://www.facebook.com/photo.php?v=667298030008133&stream_ref=10
I spoke to him a few times real nice fellow. it sounds like he is very pleased with the EFR turbo and its powerband, he said it feels like an angry 8cylinder under the hood
The fitment on something like an EVO is such a pain.. I'm in the process now of TRYING to figure out how to mount one... but because they are so bulky, its difficult. In something like a GTR, it would be epic!
Evans-Tuning did a great back to back comparison test on a built evo: EFR9180 1.05 a/r (solid line) @42psi boost (dropping to 38psi) - vs - GT4088R 1.06 a/r (dotted line) @40psi (dropping to 34psi), exhaust is 3" -- the end result is well worth the effort.
10001475_10152281695592527_1737921528_n.
1240484_10152281695692527_545498330_n.jp
In regards to the high mount, while most people mounting the turbo this way in a street application, wouldn't notice the change in weight distribution, they WILL notice the increase in intercooler pipe length as it contributes to longer spool times and longer transient response time, in comparison to a low mount setup. And I do agree, Evo's generally have poor dump pipe designs.. so where is the harm in trying to optimise this area?
If you wanted to keep A/C, fitting the largest EFR's, with (2) external wastegates is not that big of a deal. either notch the trans OR remove the integrated-BOV OR remove the AC and run a non-AC manifold ..Yes you will have to run a tight radius downpipe to clear the oem AC compressor, but really -- if you have to keep A/C, you do not have a race car... I fully appreciate engineering the vehicle to an optimum state, but I think its most important to pick your battles and be reasonable... plus 4G63s are generally more resisitant to backpressure restriction than many other engines like honda vtec or rb26
Fitting the T4 divided is not that simple. Not for a daily driver anyways. The CHRA is longer then the generic Precision or Garrett offering, and so is the turbine housing. Add this in with the bulky compressor cover, and it is a real struggle to fit downlow.
1. You need to notch the gearbox mount
2. If your keeping the A/C in the stock location (I'm currently looking into relocation or replacement with electric), the radius on the dump pipe would be and is horrible.
Mounting internal (or external gate) in high mount configuration has its own issues;
1. Your moving a significant amount of weight HIGHER in the front of the car. It doesn't promote good handling.
2. The 'lower intercooler pipe' or turbo to intercooler pipe has increased length over a low mount, thus kinda defying the whole point of using an EFR - Loosing transient response
The actual construction of the manifold isn't that hard, its more how everything sits. If you can manage to relocate the A/C to give you a better radius on the dump pipe, it would be perfect....
i have a t4 divided EFR and AC on my evo street car (with EFR internal-WG). my gearbox is not notched and cold AC is in place. I am running 30+psi on E85 daily at 600whp and can honestly say that moving the turbo up 8" and extending the cold side charge pipe 7" makes no appreciable difference. Ive compared logs to many other 8374 evos and have seen no change in boost or spool.. In no way does a slightly longer 2.5" pipe negate the performance that an EFR turbo brings to the table... external wastegates or lowering the CG of my turbo would make >zero< difference on a street car and most unibody front engine track cars. I dont think it will hold back any WTAC competitors, let alone a street driven vehicle
Edited by Full-Race Geoff
  • Like 1
I don't want a BOV on the compressor housing, or a stupidly long internal gate housing. I have a Tig welder handy which can place both exactly where they need to be to fit. What I am looking for is the EFR pictured above, Tial housing and all. The shaft speed sensor can even get farked.
tial vband garett turbo vs BW EFR B1 vband ewg:
also - here is an RX7 that went from GTX40R to EFR9180, the EFR was slightly smaller and fit better..
I can tell you, keeping the split pulse is nowhere near as important as getting the Ti wheels in there... I believe the whole split V single debate is a bit of a crock.
Typically the change from singlescroll to twinscroll is best described as a 10-15% improvement in turbine efficiency at low engine speeds & the twinscroll may have 3-5% less top end compared to singlescroll, due to the increased wall friction found on the divider surface. ive run EFR's singlescroll and ive run them twinscroll, on the same engine. to say that there is no difference and the Ti wheel is all that matters would be selling yourself very short
I also got off the twin scroll bandwagon a while ago. I found that the fancier dyno graph wasn't worth the less exciting linear feel.
for twinscroll to work right, you need the right manifold, the right turbo and the right turbine housing. If the pieces arent there or the turbo is undersized you probably wont appreciate the benefit..
The BOV is incorporated for only one reason, the shaft would fail if you didn't run a bov at a guess, too brittle.
that is completely false on many levels. First of all, the shaft is 4340 steel - far from brittle. second the EFR turbos are over 13 times stronger in thrust handling than any journal bearing turbos. I say over 13 times because we dont know exactly, the lab equipment can not damage EFR turbos due to axial thrust loading, we simply could not generate enough axial force to damage the bearing or wheels. In all honesty I have not heard of any EFR damaged from missing BOV either... I think its stupid as hell, but I would not expect a shaft failure as they are not weak
please stop posting misinformation. it is a disservice to the community and removes credibility from your statements
wouldn't a IAT/EGT sensor combo and a tune pushed to the limits of diminishing returns be enough to tell you if you are in its "efficiency zone"...?
No, an IAT/EGT are good data to have on hand, but will tell you very very little about where the turbo is operating. altitude, boost leaks, BOV faults, turbo sizing, so much great info can be easily extrapolated by simply knowing the max turbocharger shaft speed. For example an EFR8374 has a max speed of 128k rpm. here is the speed area where my car normally operates:
1902740_10152178565917527_721180374_n.jp
after 14 months of driving like a maniac and barely any maintenance, i noticed the car was feeling sluggish one morning. I looked down and saw:
https://www.facebook.com/FullRaceMotorsports/photos/a.10151959103532527.1073741828.157954962526/10152293546542527/?type=1
obviously it is spinning very fast to make this boost... there is a leak and i had to fix it. I knew this from the driver's seat in seconds, without stopping or pulling over/popping the hood. On the other end of the spectrum you can use turbospeed as an input to your standalone engine managment and use it to control a LOT of engine operation. AEM infinity has a good start on this and ProEFI also has some features in place.
there was only (1) turbo failure in the last 1.5 years that I am aware of - an EFR9180 on a 2jz supra with massive boost leaks, trying to do full boost dyno runs. otherwise i dont know of any recent failures, thats saying a lot considering how many of these turbos Full-Race sells
^^i think you and I are talking about the same guy. it may have been a questionable turbo from the outset, i dont know. either way we warrantied it and have not had any issues since that time
  • Like 1
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
