Those exhaust versus intake manifold pressure levels are pretty unacceptable imho. You'll find at that kind of level your engine VE will be plummeting compared to normal, if it's even sustainable My take away from that is the 7670 is a terrible call for that engine setup - at least at those rpm.
Nismo32ish - because the way the thread convo has panned out I feel compelled to point out that these theoretical numbers AREN'T for E70 like the earlier discussion could lead one to think.
Would the 8374 had been a better choice for my 3.2 build for response , I was looking at the 8374 when I was sourcing parts but was recommended to get the 6262, that turned out to be a 6266. Just wondering, Paul is being a pest,lol
I'd have gone an EFR8374 over a Precision 6266 on your car with what you were after, money being no object. I'm certain it'd be a nicer setup - though I'm not really so sure it'd be worth the money and effort changing now that you have the 6266 - though. Depends on if you still feel it needs more snap? Maybe try and find someone with an EFR on board?
Edited by Lithium
See what I mean about a pest :)
When I said OK to the 6262 it was going on the 2.6 as luck had it they put the 6266 on ?? so I thought I would leave it on and see how it goes with the 3.2 and it is pretty good but the 8374 seems to get going a bit earlier and I would like a bit more snap but happy with the way it goes.
If I ever decided to change the 6266 to a 8374, is there much extra work to fit it on the setup I have now?
Dump pipe won't line up and a slight pipe mod to the pipe that runs from the turbo outlet to the guard.
This is your fault, making me think about another stupid Turbo that probably not worth the exchange for the extra go ?
Hard to find out much about the 2 but there does not seem to be much in it, the 8374 seems to spool a little earlier, but very little from what I could see, but ??
The PT6266 CEA is Gen 2
Edited by Nismo 3.2ish
For what it's worth Pete, just leave it alone and drive it. Honestly.
  • Like 1
This is exactly right. That 6266 makes serious top end (I would think compares better to the air works 8376 s300sxe I posted). Only problem is there isn't s lick of data on precision turbos and I'm a mechanical engineer. I like designing before I commit my money!
Totally true!
Didn't want to make TOO many changes. This would be closer to racegas.
FYI I've started working on timing. WOW...BIG changes!
Be prepared for new dyno numbers! Haltech is super conservative! This car just picked up a definite seat of the pants increase at only 2 deg advance...and NO KNOCK.
EDIT - just reviewed log and Fuel pressure is dropping off on top end. I'm betting I've maxed the DW300 pump. It hung in there pretty well...any clue on what -6 AN lines and stock fuel lines will do? Am I limited there as well while I'm making changes?
  • Like 1
I have the Haltech 2500 Elite ECU, having some spiking problems. Went back and had a tune touch up and seemed to fix it but the weather went cold and I am having the same problem @ 4000rpm + after it is on full boost. It spikes and the ECU makes it drop back for a split second and off it goes again. Just needs a touch up again to sort it out , but I was wondering, the HKS evc 6 boost controller was taken off and then the ECU was running the show,
Would the same spiking situation be happening if the HKS boost controller was controlling the boost, I am not changing anything, just wondering ?
ECU should do a better job than the evc. Extreme temperature swings will challenge any system at full boost. Mention it next time you are in the shop but I wouldn't think it justifies a special trip.
This was explained and I do understand.
Just wondering, the adjustments had been made to the tune on a cold day and it was great for a couple of weeks, then the weather started turning cold up here when it started happening again. I usually go early in the morning, at the coldest time of the day, so I waited until 2pm when it was much warmer and ran it again, same thing happens.
This only happens on E85 and it makes 75KW more than 98 pump @ around 4000rpm , could this cause the spike as it wants to keep boosting and the ECU steps in and stops it and brings it back to where the boost should be..
I am not worried, I am with a great shop that looks after their customers, just good to get feedback from blokes that know what they are talking about and you may find it interesting or have had the same experience :/
lower the base duty and let the closed loop do the rest
He is trying to hold the wastegate shut as long as he can to build the boost faster, looks like it has to be less aggressive for the colder weather , boohoo .
Add a trim knob. Not sure how it works on those models but in closed loop on platinum the trim knob can lower the target boost (and resultant tables). In open loop it drops duty cycle by a certain percent.
How much spike
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
