1 hour ago, mr skidz said:
I can post back another log when I'm on E85 if people want?
although some people get all sensitive and upset when I post actual data. emoji23.png
How about you post up your dyno sheet of your 5's and a built 2.8L and Brett can post his sheet of his 8374 on a stock 2.6L and everyone can see how the lil 2.6L belts you by over 100kw everywhere from 4000rpm to 8000rpm? Now thats ACTUAL data! ?
20 minutes ago, Lithium said:
I'm sure no one could flame you for that, any reason I can think of which would make you do that suggests things aren't going well for you :(
He hasn't installed it yet. Too busy trying to sell his -5's with the plethora of them for sale ATM. Haha.
How about you post up your dyno sheet of your 5's and a built 2.8L and Brett can post his sheet of his 8374 on a stock 2.6L and everyone can see how the lil 2.6L belts you by over 100kw everywhere from 4000rpm to 8000rpm? Now thats ACTUAL data! [emoji14]
Sweet if it looks as stock and clean as my engine Bay does using an r32 airbox and using 98 I'm in57ba35dc4e61c38980476bc78dd67236.jpg
should provide a log with:
  • MAP
  • RPM
  • TPS
  • Gear
  • VSS
  • Time
Then go for a drive shift 2nd to 3rd to 4th to 5th
Then we can analyse the RPM vs TPS vs MAP... what you will see is when TPS is 0%  and as TPS reaches 100% again in between gear changes that boost falls on it's arse and takes a few moments to come back on.
Actually looks cleaner to me.... Lets see how much of your "stock airbox" is left? Bet it looks like swiss cheese ?
Plus i bet his engine bay is alot cooler and easier to work on than yours ?
Pros and cons for everything i guess... Look stock go slow... Look modded go fast.... Its an individual preference and i respect that fact.
End of the Day you trying to make your car go fast? Im gunna bet the answer is yes.
Reality is regardless of what your engine bay looks like if the PO PO is gunna pull you over they aren't gunna start looking for mods. They will just send you over the pits and you will be screwed just like the other blokes with the faster "non stock" looking engine bays.
10 minutes ago, mr skidz said:
If you're boost still falls off that bad in between gears you need a new tuner..lol
Pretty happy with my tuna, I'm sure others are too.
12 minutes ago, mr skidz said:
Well DOSE if you're interested in drag racing data, Which I couldn't give two shits about emoji47.png
wouldn't you have the flat shift function enebled using a H pattern!!
Well Mr Skidz, I'm actually more interested in your transient response :)
I'm not a drag racing kind of guy either, not sure if you haven't noticed at all?
  • Like 1
8 minutes ago, r32-25t said:
I know of a guy that will buy them from you, damage them and then send them back for a refund
Owch man! Haha.
speaking of which arrived today. Let's see how I sent them.
Anyone can buy anything and then complain 4.5 months later that they're buggered. Without ANY evidence, PayPal rules in the buyers favour.
I WILL NEVER USE PAYPAL AGAIN!
Anyway, back to EFR's!
4 minutes ago, reaper said:
Sorry guys can't help you with any logs I got a bit carried away
Good news is the complete bolt on 8374 setup is now available so you too can enjoy :D
Is that your car now? You don't much around, mate!
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
