11 hours ago, GTR_JOEY said:
Yea but I wanted to see how responsive I could get it, would have destroyed most twins ???
How soon will the EFR be going on? Next weekend? :D. You'll have to plumb those gates in but that won't be hard.
  • Like 1
So does anyone know a 7670 result out there that makes it a no brainer decision? I have spent this morning again cruising google and can only find one old article which supports what i was saying about the SR20 comparison.
http://blog.perrinperformance.com/borg-warner-efr7670-turbo-exposed-and-tuned-part-2/
I did see some good results on a std EVO X ... i think i am going to stick with what i got :(
Have you have a good read through the EFR thread on EvoM? That thread is a wealth of information.
Yeh, there are some Evo 8 thru 10 results that tempt me..but bascally its 3076 response and power with  better transient response.  Which is ....wishy washy stuff. Tempted to just go 7163 and give it a gut full and at least habe it all in...but that is wooftah 427ci cave man stuff. Its a turbo car....it shoudl be about soaring top end :)
I went from a HTA3076 to a 7670 on my RB25. Dyno graph in this thread somewhere of initial tune. Picked up power everywhere, much better car for the change. Approx 75hp gain (top end, now) since final tune with minimal loss down low.
6boost, 1.05ts. I have since added heavier waste gate springs and picked up another 30hp and had a slight improvement in response. Next job will be to replace the cooler piping as it goes from 2.5 turbo exit to 4 back to 3 for cooler then exits as 3 straight into 4 upto inlet manifold. It's not ideal.
Steady up lol, I'm not even back yet,
hopefully not not too much goes wrong and I can have in bolted together and ready to go in a couple of weeks.
already spoke to Dennis, gates are getting plumbed in ?
Excellent!
just don't go pushing aside a white 33. Haha
  • Like 1
Where are you getting this info Roy lol? A 7670 will punch holes in a GTX & GT3076!
Ive never heard of an GT's going 410kw?350-360kw max. Yeah the GTX will blow 400kw but its ALOT laggier!
Whats this its "only transient and response" its better? Transient response on the track and on the street is king!
SAU is being a turd. If it lets me i will load a GTX3076 vs 7670 result for you.
Both are T3 .82/.83 results on an evo.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
