[Closed] Borg Warner Efr Series Turbos
Lithium
On 8/10/2016 at 11:48 PM, VFRegal said:
Yes please. I have the TS 7163 IWG on SR20. Interested in others results.
Cheers
It is on a single scroll manifold I think and stock camshafts, solid lifter conversion to head, will be on E85.
  • Like 1
2 hours ago, acsplit said:
We don't care about peak power, how does it drive?
Only going off the info I had on hand at the time (an email that came through).  How does it drive? Can't comment on how it drives now but as it was said earlier, "un optimised" it was a significant improvement in every way compared to the -5's. That's been said a few times now though so it's going to be interesting to see how much it's improved again in its finished state.
10 hours ago, HarrisRacing said:
Treadstoneperformance (TRE) you can weld 3" on the inside of theirs and 3.5" on the outside.
3" assembly:
http://www.treadstoneperformance.com/product.phtml?p=68259&cat_key=613&prodname=Borg+Warner+EFR+Turbine+Housing+V+Band+Clamp
Both 3 and 3.5" flange:
http://www.treadstoneperformance.com/product.phtml?p=2542&prodname=Borg+Warner+EFR+Turbine+Housing+V+Band+Flange+3.5%22+Downpipe
I would not waste my time going 3" again
Nah, exhaust is sorted and am getting 3.5" made, was wondering about the compressor outlet flange, if you hack the end off its a vband, but not all v bands are created equal, (eg one my fabricator has bulk sets of has rubber sealing rings), just trying I figure out what people have used with success.
CC73D353-13A2-46CB-896D-95600D961DC0_zps
Thats what Hypertune did on mine, Pete. 2.5 inch to 3 inch 90 degree elbow.
  • Like 1
Careful...you will break down on the last lap of a race like Toyota at Le Mans when you use Wiggins clamps :)
Looks neat. A friend who has owned a few ex Gibson cars say that over time they can vibrate open so not a bad idea to just put a cable tie around them. Seems odd but i am not going to argue as mine are all hidden by diffuser etc and not accessible and be a head fark if they ever opened.
  • Like 1
On 8/10/2016 at 8:14 PM, Piggaz said:
Nicks car just in.
-5's 424 rwkw at 24 psi
8374 1.05 462 awkw at 24 psi.
Same setup, same engine. 3.0, 9.0:1 comp, 260 poncams. No graph yet.
Wind it up to 32 psi mate - should see 500-520kw :D
I'm gagging for those SR20 results. A fair few results on SR22DET or SR20VET or SR22VET.... but not much with a more 'simple' smaller cam, standard-ish SR20det setup. Would love to see what poncam, e85, t4 ts mani and EFR 7163 would look like (graph)
Ok here are some results.
SR20DET, forged bottom end, sold lifter conversion stock cams I think or maybe baby ones.
EFR 7163 IWG on old school manifold not sure if twin scroll, T4 twin scroll exhaust housing ( not sure of size)
E85 run in tune made 270rwkw @19 psi, 305rwkw@25 psi. Makes 16psi @3000 rpm and looks like it is a response monster.
I think the owner will get it back to shake it down before they lean on it anymore as it's a fresh motor.
Sounds good. Would love to know if you could confirm manifold and cams being used. Was expecting a LITTLE more if it's a T4 TS mani. SR20's do love a cam increase, so will hurt it alot if running stock cam.
Got a dyno sheet?
It was a manifold built 15 years ago so I doubt it is split pulse. No dyno sheet yet.
I also assume the ignition is very light on for this run in tune, also don't know how good the exhaust is as it's 15 years old (but has only done 5000 kms)
stock sr20, 260 procams, E85. TS T4 7163 IWG on fullrace mani and dump.
Boost issues.
Boost issues.
Dropping boost on top? Mine was on the medium cannister. It's almost as if these things should ship with high boost cans factory. Was cool to see my car make 376 whp on 11 psi though!
Yeah been a bit of an ongoing stuff around. FR shipped the wrong high booster cannister for TS frame. So then got a turbosmart dual port locally. It wouldn't hold boost. So changed EBC to one which can have different duties at different rpm but apparently made no difference on the dyno. Pretty much I don't think tuner likes the turbo :blink:.
Yep. No way to keep boost high enough on top end without changing duty cycle throughout rpm. Mine is almost linear on duty cycle for rpms after it onsets.
  • Like 1
