Firstly id like to know if anyone on SAU has gone down the twin EFR7163 path and what kind of results did they net. The turbo is rated at 550hp so would you need to run big boost to hit 1000 ?
I did have a set very early on (3yrs ago), they were prototypes so I'm not sure if the current 7163's are the same config.
Paul is correct, 20psi around 5500 and went on to make approx 600hp from memory. Didn't push them past 20psi so I have no idea where they would end up.
Roughly 1,000,000 going by Borg Warner's claims for them - they are beyond the Garrett GT3076R/HKS 3037s in flow rating, which used to be strictly "Pro GTR" type territory in the good old days of Japan drag racing. Serious serious business, so that lag isn't that surprising and realistically actually pretty impressive given what would have happened if you wound the boost up to 11. Not really ideal on a 2.6litre circuit car though!
When i started my build i had roll drags and 1/4 drag as my main priority. Ive since become more roll and top speed oriented seeing that i want to attend SM1000 next year. Ive got a 2.8 stroker with 288deg kelford cams, i think my cams might be to big for these turbos? I will be on E85, high comp and big boost. I do not want to make another mistake in my turbo choice. Its either going to be twin EFR's or a big single huffer for me.
Edited by Tyranus
Hello Guys,
Been reading this topic for a while now ... just caught up :P
Just orderd an 7670 1.05 a few minutes ago for my rb25 build (r33)
Hoping to get around the 500bhp out of this setup for a nice quick street car :)
rb26 crank
rb26 JE pistons
Eagle rods
custom manifold (2 38mm tial mvs)
delete the vct and put kelford 262 cams in there
Supertech springs
And the suporting mods for these kind of setups(fuel pump/injectors etc)
All will be at euro 98 fuel since we can get that at most places here.
  • Like 1
Hello Guys,
rb26 crank
rb26 JE pistons
Eagle rods
Supertech springs
Sounds like an awesome setup!
So you can put some super sick Kelford cams on It Paul.. Farrrrkkk don't you know anything?
Kelford are awesome, I'd put them on anything except an RB25 - nfi why they don't do a VCT cam for them... my only guess is they don't sell enough for those motors to justify the R&D :(
I need to purchase the cams so its not set yet.
Its just that I want to see something else then the std choices everybody makes.
Hope that it would not be a bad choice to delete the vct that it would realy effect the power.
Guest
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
