John, what are you you running in your gtr anyway? You inspired me to go twin efr a few years ago but I never really know your whole story
Slightly off topic but some pics from last night's clean. Excuse the shit pics, crap phone and a couple of beers too many!
post-53650-0-36734600-1417387104_thumb.jpgpost-53650-0-34158500-1417387105_thumb.jpgpost-53650-0-08653600-1417387106_thumb.jpgpost-53650-0-58456600-1417387106_thumb.jpg
post-53650-0-92864100-1417387107_thumb.jpgpost-53650-0-65566400-1417387108_thumb.jpgpost-53650-0-51171200-1417387109_thumb.jpgpost-53650-0-24306800-1417387110_thumb.jpg
  • Like 3
Very nice, that wing is massive, what is it and where did you get it if you don't mind me asking :)
It's a custom job by Andrew at Custom Carbon Creations or CCC. Designed by Scott Beaton from Aero Design, the guy behind the WTAC rules.
I've recently cut it down 100mm each side also, was huge back then!
Did you get the proshonk stuff sorted?
Love the green wheels
Not yet, car is resting until next year now. I've ordered some replacement LCA's and just need to make new hats and dogbones to better space the rotor.
Thanks, matches the green roll cage also (can't really see that in the pics)
No twin scroll? :(
Im thinking about going to a 7163 and getting rid of my oil leaking FP green on my evo as FR have a lowmount kit out/coming out. I believe Geoff has 1 on his evo now.. Id love to hear how thats going and what fitment is like from Geoff. I wouldn't wanna sacrifice any response over the green even though i know its a 6lb bigger turbo..
Do it! The EFR7163 will blow the FP green out of the water....
All though it is a lot of money for not much more top end (if any)... Might be better to look at a twin scroll EFR7670??
Edited by Tonba
  • Like 1
Haha im pretty confident that the EFR will smoke the HTA. But i dont wanna sacrifice ANY response. Im not after top end at all Alex its the midrange & response i seek :) id also like to stay lowmount.
  • Like 1
To be honest id be happy with 330-350kw max but i just want the most responsive setup with most area under the curve i can. The green starts moving in lower gears at around 3700 that'd be as laggy as id like.. As you know Point to point there isn't much faster than an evo.. I want to keep to that recipe as much as possible with my car as it suits the style of driving i enjoy most. :)
How about you grab a 7163 or a 7064 and tell me if it's nicer than your GTX3071 :P Then maybe i'll chuck one on my 34...
I've seen a couple of tests where the 6258 doesn't really outspool the 6758 despite the smaller wheel and falling off much sooner. IIRC one comparison was on the ART silvia and the other was a Perrin test.
Given how fast the 6758 spools it doesnt matter too much, but still, anyone know what the deal is?
Edited by Skepticism
I don't know for sure what the story is there, I have seen ones where the 6258 comes on quicker but either way I do know and have before seen dyno plots which don't represent what happens in the real world - at least in terms of response. Might investigate but either way I see no reason in going smaller than a 6758 as a single turbo on something aftermarket
Is anyone running an EFR8374 with 0.92 A/R T4 twin scroll (internal wastegate) on an RB25/26?
What sort of power could be made with this turbo, WMI setup and other required supporting mods? I have not been able to find much info about actual results with this turbo.
Cheers
Justin
Cheers
Justin
I'm running one on an RB30/26 ?
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
