Here is a 6266 on a 2.6 on what I assume is the same dyno. Notice it goes to 210km/h so scaling is different.
Assuming 8k limit, @135km/h its on full song at about 5200.
Edited by burn4005
True ebough, if its 7.5 its more like 5k.
I'd be interested to hear what the scaling actually is. I've always liked the efr83s as my next turbo, so if he's let off at 7.5k ish and making that power on a 2.6 I'll be extremely impressed with it.
As with most things I don't think the dyno plot can explain the response of it, but I'm betting its miles better than dash 5s at circa 2 bar. The efr looks like it comes on very smoothly.
Edited by burn4005
Going off what Brett has said. 22 psi was reached at 4300 RPM which on that graph is 105 km/h. It's making just on 300 kW at that point.
Posting on behalf of "Reaper".
Stock N1 engine (V spec II nur)
Borgwarner EFR 8374 1.05 AR rear
AI industries surge tank and Holley 1800 dominator pump with Walbro E85 intank pump
Bosch 2200cc injectors
Tial 44mm wastegates
Full Race twin scroll
4" dump into 3.5" kakimoto exhaust
ATS carbon twin clutch
HKS 100mm intercooler
HKS Step 1 V cam (248 @ 8.6mm)
AAF5E4D7-F072-4218-B83D-7D64932E8EAD_zps
Jezzebelle stopped there because of the standard engine.
* Green line is as it was dropped off, Red line was the final result.
stock longblock, small cams and simple setup! this car is probably much more fun than a dynosheet can explain, hopefully Reaper is pleased with the outcome
  • Like 1
2jz with twin 6258s -- slightly OT, but too cool not to share:
"Geoff, wanted to keep you in the loop. Re dyno'd the twin 6258 IWG car on E85. Got her to 32-33 psi and ended up with 922 whp and 790 tq at 4600 rpm !! This is a 8.5-1 engine with a stock head and 264 stock base circle cams. Wowzer…I attached the dyno chart with the C16 vs E85 max effort pulls.. So impressed really. Cant wait to fire my car up with 7163’s…Thank you
Eric"
Edited by Full-Race Geoff
  • Like 1
at 4k $ the v-cam are far from ''small simple cams '' IMO :)
Edited by cobrAA
Its a type a vcam intake with a type b poncam exhaust so they are pretty small especially considering no porting or anything at all.
  • Like 1
5th gear, 285/30/18 rsr's and standard 34 gtr diff ratios with the standard 6 speed
Can't have been 5th gear.
5th @8000rpm is 220. top of 4th is 168km/h. which matches plot exactly.
so full boost@115km/h is 5475rpm.
300kw @ 5000rpm
400kw @ 6000rpm
***ignore above.. bad maths***
Edited by burn4005
whoops! they are, good pickup.. sorry i under calculated the tyre circumference.
using circumference 1973.55mm (https://www.mcgrefer.com/sizeinfo/2853018) for a 285/30/R18
speed peak of dyno of 169km/h in each gear:
3rd (1,685): 8500rpm.
4th: (1,312) 6650rpm
5th: (1.000) 5050rpm
it appears it was done in 3rd.. could an 8500rpm readline be correct?
that means spooling (10psi) around 4500 and full boost (27psi) at 5800rpm
Edited by burn4005
No.
BDD1D388-D7FB-4173-A70D-1D94542F4DDE_zps
There is a graph from very early on in the tuning process. 10 psi at 4500?
Guest
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
