Hi Geoff,
I noticed there's a new rear for the 6258's. Has there been any testing done against the original .64 rear ??
Would be interested to hear the resulting differences between the two...
(is it wrong to say I'm getting bored with only 500kw..??) :rofl2:
lol :ban: - in all seriousness, the singles have their place (got one on my car) but twin EFRs are next-level
hey John, have not done any back to back 0.64 vs 0.85 on an RB26 yet. built RB26's seem to prefer larger rear housings (within reason) so this is something brett was planning to do on his R34 in the next couple of months. Most of our higher power RB customers seem to go with the 6758 and 7163
it appears it was done in 3rd.. could an 8500rpm readline be correct? that means spooling (10psi) around 4500 and full boost (27psi) at 5800rpm
We typically see 1bar / 15psi around 3500rpm on 2.6L engines with the 8374. I expect we'd be flamed if our "response" based 62mm single turbo was spooling that late on an RB with vcam (10psi @4500)
  • Like 1
Hi Geoff,
Chuck up your graph again mate?
What pressure are you running to net 500 kW?
That's a fantastic result then, I was just having trouble reconciling the speed axis on that to RPM mathematically...
an EFR8374 is definately on the cards for me in the next year or so. Having Matchbot and all the turbo maps available is definitely a huge plus for the Borg. I can't make an educated decision on a 6262. its just "yea mate they're good for an RB26"..
I'm yet to stretch out my 2530s on E85, but I can't see them being as good.
Edited by burn4005
This goes back a few years now, I don't have a recent one saved anywhere as the result is always similar.
30spi dropping off, the larger rear housings might just be worth a try..
Alternatively now that I have my chassis all sorted (and bank account drained) I can probably look to go up to bigger twins or large single as I'm confident the car will now handle the extra power.
I too am curious how the .64 and .85 compare in general. I have the .64 and would consider .85 if I didn't get enough out of the .64 but going with 6758 or 7163 twins sounds nuts.
too late to convert for me now.
i like 0.64 for street cars, but im into spool, torque and power band (im an engineering nerd). for a real race car that has a racing transmission and chassis, spool is not as important as outright power. 7163 appears to be slightly more surge resistant than 6758 so that is a plus for 7163 twin installs.
great to hear you like the matchbot and data that is provided! i continue to learn all the time using that tool
swapping to stiffer IWG actuators on your existing 6258s may help carry boost in the higher RPM. turbosmart makes a quality actuator, just be aware it has less stroke than the standard BW and only 2mm preload is appropriate.
moving up to twin 7163s is worth consideration if you have the engine/displacement/head and really want to handle more power - its a direct fit to your 6258 install
So a 7670 would be sufficient to get at 600hp on e85 then?
7670 is really a 530-550hp turbo. For a true 600hp the EFR 8374 is the call. Internal WG with a stiff actuator gets it done nicely on E85 and a simple setup
Edited by Full-Race Geoff
  • Like 1
So on the topic of the efr wastegates I've been hearing more feedback from local tuners who struggle to have no boost creep or have unstable boost at whatever Desired setting and blade the efr wg. The builder/tuner is now pushing to change to the turbo smart actuators stating that they are just right. Why isn't anyone else reporting these issues? Also looks like it's a very tight fit fit with the efr actuators, will the turbosmart fit twins on the gtr?
As for turbo selection, I wasn't going after big power but my build took a few turns which is why I asked about the larger housings. I am after the low and mid range power.... I did not select the cams.
I run:
Tomei 2.8 short block (n1)
Tomei +1mm valves along with all their head upgrades and 290 deg 11.5mm lift cams
Ppg 1-5 helidog gear box and so on
So obviously it's too late to try and sell my turbos in favor of larger ones (hough they are new, people rarely buy 2 efrs at once) but I'm also not after huge power. So I should be OK with the smaller 6258 then...
I'd be happy with 600whp.
Edited by NismoSTune
I am after the low and mid range power...I'm also not after huge power. So I should be OK with the smaller 6258 then...I'd be happy with 600whp.
i believe 6258 0.64 is probably the perfect choice for you. Im running these turbos as twins on my current 3.5L v6 project. The turbosmart actuators will fit just fine.
We've seen excellent results with the OEM borgwarner stiff wastegate actuators -- up to 28psi. This is how borgwarner designed them and it works quite well. The original intent was to release a stiffer "higher boost actuator" that would go to 40psi. however the turbosmart options works very well and bw chose to focus on some other alternatives you may see at sema this year.
for more IWG control or for boost levels far beyond 28psi then the turbosmarts are an excellent choice. I personally worked with Jon at BW and we used alicat scientific equipment to provide turbosmart with our input on how to tweak and refine the IWG dual port before public release. They took our input into consideration and produced a nice quality gate. it is not at all mandatory, but it does have its place in the market
My turbo manifold shipped today. I should have results of a pretty stout stroker 2.75L with ported head, +.5mm valves, springs, cams, hypertune V2, etc shortly on a 6boost manifold and 8374 EFR with .92 IWG setup.
I'd say I should have dyno results within 2 months max. I have had the "two steps forward, one back" constantly on my project so it's taken me forever waiting on new parts and fabbing stuff.
I never had issues with boost control on my T4 IWG 7163. Boost was always easy to control, but the tuner and I went for a creeping boost curve to give a nice powerband.
This is a 9.5:1 compression sr20vet (still 2L) by the way. Intake cam was advanced 4 cam degrees and the exhaust retarded 1 or 2. I will go again for a retune with +2 intake and - 1 exhaust which should bump power up a bit. I'll also fab up a 3.5" down/front pipe.
This dyno reads pretty low compared to most in Sydney. Slight dip in the power curve was because of a slight misfire. It made a few extra KW in a later pull (346kw) but i'm pretty happy with how it drives considering it makes this much power. The tuner was just so impressed and said this was way ahead of a normal sr22det with a gt3076r he tuned.
  • Like 1
Geoff you mean 2 boost controllers and 2 waste gates... right? Not 1 and 2?
Each turbo has its own solenoid is what I was told when I bought the twins, not 1 solenoid that splits to 2 turbos...
No, two boost controllers will give instability as the integrals will fight each other. One solenoid goes to the two actuators. They should have the same preload so their opening characteristics are the same. Usually you wind up an air compressor regulator and make sure they move in unison.
Guest
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
