Jeff, any 76mm sx-e in t4? they seem hard to get...
hi, we have good stock of SXE turbos. shoot me an email with exactly what youre looking for and i can help (76mm inducer or exducer). thanks
@harris racing, good start! like the others have said, check your iwg spring rate and tension. there is defintely room to be had with tweaks
  • Like 1
You're running internal gate? Do you mean whether you get the soft, medium or hard spring in the internal actuator?
I have the medium cannister for now since I'm going to be strictly pump gas and wanted to tune the bottom of the map for road course racing (potentially on lower boost).
He's talking about setting the tension on the wastegate cannister by turning the nut in and out to tighten the wastegate spring. The procedure is in the BW EFR manual and on Full Race's site. I actually forgot that I ZERO'd the boost tables for break in so this is totally on the wastegate spring with boost signal to it right now. I will set the boost today or tomorrow and get it to spool faster. Haltech boost control is pretty dang detailed. There is DEFINITELY more spool in this thing I assure you.
I think I defaulted to 2 or 3 turns (wrote it down in my notebook at the shop), just for breaking in the engine. It did creep to about 11 psi the other night at 7500 rpms but again I need to check boost settings. STAY TUNED! But the turbo is hyper responsive...I LOVE IT.
Hey guys, just wondering if anyone have or looked at bw sxe series turbos?
Compressor Specifications
Compressor Type: Forged-Milled Wheel (FMW) Extended Tip
Compressor Wheel OD (exducer): 83mm
Compressor Wheel Inducer: 61.5mm
Max Flow Rate: 75 lb/min
Compressor Housing Connections:
Inlet: 4.0" Hose Coupler
Outlet: 2.5" Hose Coupler
Turbine Specifications
Turbine Type: Inconel S300SX Turbine Wheel
Turbine Wheel OD: 76mm
Rear housing twin scroll .91
Just looking for any feed back
Thanks guys
Thanks guys
It should compare very closely to the 8374 EFR with slightly less response and slightly less power since it has the same compressor wheel, but will have less response and slightly less power due to the exhaust turbine differences and oil-only journal bearing (which really isn't that big of a deal to most anyway).
On pumpgas it would likely be a perfect turbo choice for a stock displacement or drop-in camshaft RB26. And for the money ($760 USD!)...wow it's got to be one of the best turbos on the market especially if you have the turbo manifold and wastegate already. Also if used on a stock displacement RB26 I would stick with the .91 twin scroll housing for better boost threshold.
^^mostly agree with Harris Racing. bang for the buck, nothing can touch these SXE turbos. Keep in mind this turbo he's asking about has a 76mm turbine wheel. this is slightly larger than the EFR8374 which uses a 74mm turbine wheel. As a result the SXE may exhibit reduced emap in exchange for the later spool and response time
Got my first drive in a mates RB30 8374/1.05 tonight. What an absolute BEAST of a turbo. Half throttle between gears and its INSTANTLY back on. This car had -5's on it previously and there is NOOOOOO COMPARISON in ANY way.
This once again reinforces what the guys with EFR's talk about.
  • Like 1
I f**king told you so ;)
  • Like 1
You sir are the bearer of bad news. I don't want to hear this
I ended up buying another 240z today with a LS1 in it hahahaha. GTR and all the head parts I just purchased are gonna be put on the back burner again.
Totally. I still haven't touched my timing maps yet and I'm still on only 10 psi boost and the turbo just wants to spool. I can leave it in 5th and pass anyone on the highway that I need to (of course 75mph is somewhere around 3k). Drivability is truly incredible I'll get videos of inside the car later today hopefully.
Paul you've changed!
Clearly not a fan of response anymore?
EVERY GTR owner knows you go twins for response! :P
  • Like 3
While I haven't driven an EFR RB engine (yet) we've installed one on my friend's FD with stock ports and all bolt ons. . .It's on a base tune right now with 8 psi and it's insane at how quick it spools. . .no delay whatsoever. . .My FD is getting the 9174 treatment in a couple of weeks :D
How does it compare to mine? Guess you worked out the oil issues
I haven't driven yours. I only used no more than 50% throttle and no more than 5500 RPM absolute tops.
It's imediately back on pipe. Makes the precisions between gears seem like a mid 90's turbo.
A dyno sheet won't give you a good idea of how it goes about its thing. That's what every owner of an EFR owner talks about.
Guest
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
