Blue is 98, Red is E85
This is with the 7psi springs so will be interesting to see if response picks up with a 14psi springs.
It's also with 272 cams, bigger than the general consensus on here...
Car has run 130mph with my big ass in it, so it makes the power no question.
It will.
It will start spooling earlier. Went from 7 to 15 psi spring and just ran it it off the gate to get base spring pressure and noticed the difference immediately.
What BW's would be recommended for a stock block - if you wanted to retain twins for rwc purposes?
They don't fit in stock locations. They're way too long.
This is what twins look like
AB1D3231-698F-4E76-9FD9-C49917044AE3_zps
C91700BF-E978-462A-B5F2-BD1063C7357B_zps
The smallest twin EFR's (6258's) will do 500 wkw on a well sorted setup. Brightey who posted above has a set on his RB28.
Forget the 0.92. 1.05. Better setup for when you realise the 7670 is too small :D
7670 would be great on RB25, but on RB26 i think too small for anything other than bone stock engine for autox events imo. Maybe if you were limited to low boosthe or wanted to keep revs down for some reason?
Single EFR for the "-7/-9 on a stock engine" type of build.
How does it compare to the TO4Z you drive a while back?
Speaking to a local turbo guy and he said he can mod a Zed to bring it on 800rpm earlier, make more powa, and improve the already good part throttle transient response. Not sure if its an exaggeration, but interested to hear ur thoughts.
He also mentioned these EFRs and SXEs are very very good.
[emoji2] [emoji2] [emoji2]
Id hazard a guess he'd just throw away old comp wheel and fit the ebay gtx style billet 11 blader that everybody uses?
My mechanic has a EFR 8374 on his built RB26
Made 550kw on e85 on 32-30psi
has 32psi by 4200rpm
i'll see if he'll let me put his dyno graph on here... havent been in it yet but response looks mental
i've also bought an EFR 8374.... mine should be getting overhauled in July hopefully
stock bottom end EFR 8374.... see how we go
  • Like 1
Pretty much. I think they machine the housing and put bigger wheels in them. I will find out tomorrow.
Yeah that E85 is tempting me as well.
I totally believe the 32 psi by 4200 with anywhere near a decent tune on E85.
It's funny how this turbo comes on. It will make the 10 psi on bottom end while cruising and slow spooling, but right around 3800-4k the turbo turns on. I can't wait to get mine to a solid 20 psi on pump. I can NOT imagine what 32 psi on E85 feels like!
  • Like 1
I just don't really want 500+kW, so why go bigger? More momentum etc with the bigger wheel is my logic
You should run it through matchbot, you will hit the right side wall and it will overspeed .
I have tried countless configurations on match bot and rb26/28. The efr 8374 .92 is what I have, but if I could get e85 ( none in Nippon) then I would go 1.05 and wind it up.
I've seen the light haaaaaaa!
Edited by Meathead
  • Like 3
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
