I cannot see why people are still using twin setups. If garret cannot develop a rear housing for their gtx twin range, means to me that the problem is with the rear housing. It nearly cost me an engine in 6min of track time.
The setup that Piggaz is referring to is mine.
All I can say about the setup is that I should of done it earlier and not bothered with twin -5's.
IT'S FCKN AWESOME in all areas. Just do it and you won't look back.
  • Like 1
The BW EFR turbos have a speed sensor that you can install on them to measure the rpm of the turbo. They have upper limits of course. There's a pretty fixed relationship between boost, speed and airflow (from memory, don't scold me if i'm wrong!) so it helps with safety and getting a good handle on exactly whats going on in your setup
The exact same one that sits on the back end of -5's
Ok, but that was made in the 90's. Do you know why they didn't make a newer design rear housing?
With my setup, the turbo is making noise at 2000 and at 3000 it wants to rip your face off.
Boost and flow doesn't have a fixed relationship. That's why I'm maxing out at 25psi on a 3 litre. A 4cly 2ltr would prob take 30psi before maxing out.
Keeping under the speed limit stops the turbine falling off.
ah yes my mechanic did install the speed sensor for the RPM on the compressor wheel. also recommended I get one.
he said due to the lightweight material used on BW, its a good idea to keep an eye on how fast it is spinning so you don't break it!
just post the gtx turbos up here and I'll test them for you
So you can find out 1st hand how hard they will fail and prove me right about all the shit i been harping on about in the GTX thread? Of how GTX compressors wont work with factory location housings?
Garrett put these compressor wheels in their own housings for a reason mate ;)
Honestly Pete you will be making the right move taking the EFR route.
So what if the GTX wheels turn out to be a "tad better" (which i highly doubt) will the machining costs etc be worth it? The EFR will still punch holes in them from 800rpm - 8000rpm in every single way and the money spent on machining etc goes to a manifold for the single an intake pipe, a cooler pipe change and a dump pipe.
The offset in the price wouldn't be that much different (if going IWG .92) BUT i guarantee the result and the way the car drive will be 100% better!
Guest
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
