11 hours ago, GTR_JOEY said:
Yea but I wanted to see how responsive I could get it, would have destroyed most twins ???
How soon will the EFR be going on? Next weekend? :D. You'll have to plumb those gates in but that won't be hard.
  • Like 1
So does anyone know a 7670 result out there that makes it a no brainer decision? I have spent this morning again cruising google and can only find one old article which supports what i was saying about the SR20 comparison.
http://blog.perrinperformance.com/borg-warner-efr7670-turbo-exposed-and-tuned-part-2/
I did see some good results on a std EVO X ... i think i am going to stick with what i got :(
Have you have a good read through the EFR thread on EvoM? That thread is a wealth of information.
Yeh, there are some Evo 8 thru 10 results that tempt me..but bascally its 3076 response and power with  better transient response.  Which is ....wishy washy stuff. Tempted to just go 7163 and give it a gut full and at least habe it all in...but that is wooftah 427ci cave man stuff. Its a turbo car....it shoudl be about soaring top end :)
I went from a HTA3076 to a 7670 on my RB25. Dyno graph in this thread somewhere of initial tune. Picked up power everywhere, much better car for the change. Approx 75hp gain (top end, now) since final tune with minimal loss down low.
6boost, 1.05ts. I have since added heavier waste gate springs and picked up another 30hp and had a slight improvement in response. Next job will be to replace the cooler piping as it goes from 2.5 turbo exit to 4 back to 3 for cooler then exits as 3 straight into 4 upto inlet manifold. It's not ideal.
Steady up lol, I'm not even back yet,
hopefully not not too much goes wrong and I can have in bolted together and ready to go in a couple of weeks.
already spoke to Dennis, gates are getting plumbed in ?
Excellent!
just don't go pushing aside a white 33. Haha
  • Like 1
Where are you getting this info Roy lol? A 7670 will punch holes in a GTX & GT3076!
Ive never heard of an GT's going 410kw?350-360kw max. Yeah the GTX will blow 400kw but its ALOT laggier!
Whats this its "only transient and response" its better? Transient response on the track and on the street is king!
SAU is being a turd. If it lets me i will load a GTX3076 vs 7670 result for you.
Both are T3 .82/.83 results on an evo.
Guest
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
