  On 31/07/2016 at 11:17 PM, bigmikespec said:
For the record, compressor RPM and pressure are not related... at all.
Expand
Was looking for a loose estimation on how hard a 26 would spin it In relation to boost.
but yea thanks
  On 01/08/2016 at 3:16 AM, Piggaz said:
7F40E034-348A-4E8D-A9D9-00AE447141F2_zps
R32, 6 boost high mount, 8374 IWG.
Expand
And the aircon used?
Genuinely curious, out of interest, for the sake of anyone who may wonder themselves in the future. Can't see the factory aircon line where they should be running under the compressor housing though, I think, but i think i see aircon lines wrapped in foil up at the firewall?
Expand
I believe so. Waiting on a call back from the owner of the car.
Why don't you ring 6 boob and ask? Bugger making a manifold when you don't have to. FWIW, I've never heard of the issue you're talking about. R32/full race with the PS pump yeah, not AC with a 6 boost.
If that's the case that's good.
I had been onto Kyle via email and did ask him if there were fitment issues re aircon at which point I didn't receive a reply, however by that stage i'd got onto my mate about doing it, and he was competitive on price and willing to have a got at the low mount, so I didn't bother following up more on the 6boost. I was going to far to say it wont fit, i've read too much into the fact I didn't get a reply when I specifically asked about that. Either way the car is in the fab shed with a set of flanges and elbows so we'll see what comes out
I have 6 boost on 8374 iwg .92 efr with r32 AC on my car right now. I did make a new AC line because I had cut mine previously trying to get it to fit with the RAW brokerage manifold. The dampener in line would have been close to the bottom of the manifold for sure on the stock line. I cut the ends and just had my shop sweat 2' of line in-between the end fittings and covered with heat wrap. Works perfect
Warranty issues is why no heat wrap is present. Thought about doing it anyway but it seems to work well enough.
Zero hood clearance issues (that was the problem with the RAW). Remember the 9180 is the same size as the 8374...so there's room enough for a 1,000HP turbo on here.
Ran some more boost threshold tests: Temp = 91 F, 70% humidity.
1) Third gear from 2k rpms. Graph attached - NOTE that my closed loop boost control is starting to compensate at 3390 rpms (ie starting to give supply pressure to the wastegate).
  • 10 psi @ 3430 rpms
  • 14 psi @ 3712 rpms
  • 16.5 psi @ 3909 rpms
2) 5th gear from 2k rpms. Graph attached.
  • 10 psi @ 3059 rpms
  • 14 psi @ 3200 rpms
  • 16.5 psi @ 3278 rpms
  • 18.1 psi @ 3329 rpms
So this goes to show that the EFR will spool soon when loaded for long amounts of time, but that it still has a good bit of inertia with it to get it to respond on extreme low end. As stated previously with my setup, the gear greatly affects threshold. Granted, it's still hyper responsive and the low boost threshold in 5th is nice for passing on the highways because I'm still at those rpms while cruising so there is no need for downshifting.
  • Like 4
  On 03/08/2016 at 9:08 PM, joe89 said:
HarrisRacing
Amazing spool :O
Its 2.75l? Stock head with cams? And on fuel pump?
BC 79mm stroker crank. Stock 86mm bores. Forged pistons stock compression. Squish pads mostly removed. Tomei poncam A's at 0 and 0 cam settings. 6 boost manifold divided T4 internal wastegate 8374 .92 housing hypertune V2 intake manifold and yes 93 octane fuel in the US
Guest
