Yeah man run that -5 on the track and get us some 1/4 mile results with logs. It's an exceptionally hot and humid summer here this year but when it cools I'll run the car some more.
@HarrisRacing - What exhaust manifold are you running, and what ID runners does it have?
Skidz - anything involving corners throws HEAPS of variables into the game which make it next to impossible to compare turbo performance
6boost IWG divided T4 for EFR. no clue on diameters but I'm sure I could ask Kyle.
24 minutes ago, mr skidz said:
Roll Racing sounds like something that doesn't require a steering wheel emoji14.png
Come next track day at Wakefield that trak-life & Yez Racing organise.. the September one is full unfortunately. $235 per car, untimed, unlimited track no sessions.
  • Like 1
I thought it was an invite to go have some fun not compare turbo's [emoji54]
Will do definitely at some stage last time I went to Wakefield in my last Gtr I ended up spending the whole day in rear wheel drive ripping skids with the gtst boys got some footage of it somewhere.
But I think my first track day in this car will be at the creek as I know the creek really well from many bike sessions I've done over the years I've only been to Wakefield once so I'd be useless there and besides my car still uses completely stock brakes they're not the greatest I think we all know that but for the most part it's just my streetcar / daily nothing serious just a fun car.
damnit  just went to get you guys some logs + videos and popped the axle out hammering around the first turn. Gets violent with the 3 wheel drive. need to change the circlip on the axle.
3 hours ago, Dose Pipe Sutututu said:
There are people with results however they can't be bothered sharing. One of those people just pulled off their setup to go bigger lol
Hey not my fault I pulled it apart before everyone asked for stats!
I just wanna go fast
  • Like 1
^^ Looks pretty quick!
Took the liberty of converting my dyno data from 10 psi and 17 psi and putting in excel graphs. BLUE lines are data associated with 17 psi pull, RED lines are data associated with 11 psi pull. Boost is in PSI, but is multiplied by 10 for scaling purposes (so 100=10.0 psi and 200=20.0 psi).
Also I believe the turbo would have made 380-385 whp if revved to 8k rpms on the 11 psi pull...I was hesitant at first because this was literally the first dyno pull. It did make 371 whp at 7600 rpms though.
  • Like 1
I'll get another dyno run done on this pump tune of mine out of curiosity , as my first dyno tune was over 1000rpm laggier than my current tune at 18psi when set to 25psi.
(Someone else tuned it as we needed load on the fresh engine)
Cool vids too I enjoyed watching them all
[emoji4][emoji108]
Hi :)
I have a question, what power can make 7670 1.05 on RB26 forged + cams + pb98? With no exceed 27psi?
Previously i wanna 8374 .92 but i look on HarrisRacing 2.75l RB and i think it be too laggy for stock capacity and daily drive. 7670 1.05 should spool 300-400 rpms faster?
I just need 630 EU hp on crank :D
If going 7670 I would stick with a 2.6L and stock cams. Turbo will be at maximum speed for sure and you will need to add a road rage gauge to make sure you don't destroy it from overspinning. I wouldn't suggest running the boost over 20 psi over 7k rpms. I bet it will *just* make your HP number though. It would be a VERY fun daily driver.
Reason why I say stock cams is because you will start to choke that turbo on top end on the exhaust side and larger (ie-overlapping) cams will only make the backpressure contamination worse in the cylinder.
When I was comparing the 8374 to the 7670 I think I found that the 7670 should hit full boost 500 rpms sooner than the 8374 and make similar power up until around 7k where the 8374 will continue to feed the motor. Of course I was probably looking at 2.75L at the time so I'm sure a 7670 on stock cams and 2.6L is a good choice for a street car that occasionally wants to turn up the boost.
33 minutes ago, Snara said:
Hi :)
Someone might be able to correct me if my math is wrong, but @ 27psi, but that turbo is going to be out of the efficiency range for your setup.
Guest
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
