35 minutes ago, HarrisRacing said:
If going 7670 I would stick with a 2.6L and stock cams. Turbo will be at maximum speed for sure and you will need to add a road rage gauge to make sure you don't destroy it from overspinning. I wouldn't suggest running the boost over 20 psi over 7k rpms. I bet it will *just* make your HP number though. It would be a VERY fun daily driver.
Reason why I say stock cams is because you will start to choke that turbo on top end on the exhaust side and larger (ie-overlapping) cams will only make the backpressure contamination worse in the cylinder.
When I was comparing the 8374 to the 7670 I think I found that the 7670 should hit full boost 500 rpms sooner than the 8374 and make similar power up until around 7k where the 8374 will continue to feed the motor. Of course I was probably looking at 2.75L at the time so I'm sure a 7670 on stock cams and 2.6L is a good choice for a street car that occasionally wants to turn up the boost.
Damn, well i like to reeving hard to 8200 rpm on the streets :15_yum: So maybe the way is 8374 .92
I have already forged engine, HKS SS 264, and chinese GTX35R t3 82, on 1.9b and it make 635hp but it's laggy. Car ride after 4500
Like on video, start from second gear ... i need something faster.
Edited by Snara
So u think just go with 8374 .92 ?
I am unfamiliar with the KM to HP conversion but I would guess it's the same, right? Is your HP at the wheels?
In all honesty I wouldn't spend the money changing it, as it looks like solid yet slightly high-end powerband to me. If anything spend the money on a V-cam setup and gain some bottom end that way. I mean you are on a T3 manifold so it would take significant money changing things at this point.
Also the caveat is that the dyno I have is old and doesn't represent the spool I've been able to get out of the car with bottom end changes lately. I have posted my boost threshold data lately. I too wish there was a "perfect" RB26 street turbo between the 7670 and the 8374 but it doesn't exist (yet). Apparently our high rpm band hurts what we can bolt on.
So far I'd say any of the following fit a higher boost (E85 or WMI) street car pretty well:
Precision Gen 2 6062
Borg Warner 8374 EFR (,92 or 1.05)
Borg Warner S300SXE 8376 (little more lag and little higher rpm power than 8374 journal bearing turbo)
GTX35R
Garret -5 twins (These really aren't bad turbos IMO).
I think all of these singles will beat the -5's in overall power and will be similar (if not better in some cases) in response, but that comes at a price...real money and a non-stock appearing setup.
GTX35R
Well yes KM=HP, power is on engine, on the wheels is 530HP
I have old t4 twinscroll manifold, first turbo in my project was BW 8375, it spool like chinese GTX.
Now i wanna buy some new age turbo :)
On second gear i see:
4200rpm - 0.5b
4700rpm - 1b
5100rpm - 1.5b
5600rpm - full boost
Edited by Snara
I'm throwing the -5's back into the ring here for a second :P
1) Found this dyno of a "fully built, high-rev ready, on 17 psi. 463 whp
2) Same car on 20 psi: 544 whp
3) Seems to be different car (S13) on 20 psi.
4) All stock R32 internals with -5 turbos at 18 psi. 500 whp (really looks like 492 with a smoothing hiccup at the end)
so I looked close at the dynos and found a couple of things:
My car beats them all HP to the wheels on initial spool down low in the rpm range of 3500-4700 rpms. Then those at the similar boost levels are around the same HP (which is depressing because I'm a stroker with slightly more displacement) from there to about 6k where they all start gapping me in power. Granted I NEVER touched my ignition timing up there on my dynos so I'm likely leaving a lot of power on the table still. Also I'm now convinced that the 3" exhaust is hurting me up top (and perhaps even the .92 IWG housing). I have read a lot about the IWG setups and backpressure. At high boost and high rpms (ie high EMAP situations) each 1 psi of exhaust pressure can equal up to 2-3 times the turbine/manifold pressure since this is multiplied via the physics of a turbo volute. I did notice ALL of these cars are running 3.5" exhaust.
So yeah...that.
6 minutes ago, Nismo 3.2ish said:
I see that the 8374 was first mentioned in this thread in 2010, when where they introduced?
Have they been modified at all over that time, 6 years old + ?
No.  The only changes in the WHOLE EFR range that I am aware of are:
1) The EFR6255 never ended up being a thing
2) In the earlier days there were some production issues which resulted in some failures, which are now resolved
3) The EFR7163 was released a couple of years later
4) The EFR9174 was released last year, I think
Other than that, the turbos we're talking about now are the same as what I brought up 6 years ago :10_wink:
Edited by Lithium
  • Like 1
Im a bit skeptical of the white R32 GTR in the YouTube clip it has been up for quite a while and in the comments I'm sure I read that it made that 500 wheel horsepower with standard R32 downpipes off the turbos which he said was robbing him of response.
It's hard comparing other people's set ups to your own unless you know full detailed specs especially when the engine could even be breathing heavy low on comp all sorts of issues could be there that we don't know about so it's probably best that you stick to comparing your engine to something like my own which I know has been freshly Built and I know the details inside out just need to rule out all variables for accurate comparisons.
There is no way I reckon that thing would ever on a standard 2.6 low compression or even a built engine make that Power on such little boost on petrol.
It is interesting to note he's only producing 5psi compared to my 20psi @ 3700rpm and I also start making positive boost @ 1500rpm in 4th on flat road.
So I believe him that he has the downpipes robbing him of response but that horsepower number at the wheels is a little bit inflated I reckon.
All of their response is not as strong as mine or yours though. You have a stand out -5 car from what I'm seeing compared to those.
At this stage it's only really standing out in terms of response it feels even better again as yesterday she got it's first oil change from the run in oil and put some light Grade 10/40 in there and it is a little bit snappier again.
Everything I put in the car was just there to optimise throttle response and to encourage fast spooling.
If it hurts my 600whp target on E85 im cool with that as it's not hard to change out some cams and springs as my head has been relieved already to fit high lift ones if needed.
  • Like 1
I'm digging it. I really would like some pull videos to compare to my car. It's still hot as hades here (was 95 deg F today), but I'd really like to run our videos back to back and compare setups. You know my whole setup. I'm curious to see yours.
  • Like 1
Well to be fair to your setup and rule out your restrictive 3 inch downpipe just leave it at 17 18 and we'll do that. It won't make a difference to response on my setup as closed loop boost control doesn't start working till it hits a predetermined boost level anyway
Done. Internet racing at it's finest LOL.
I must say it's really neat that we can even do this so quickly and easily separated by such long distances!
Ended up with almost exactly 4.5 sec from 5k to 8k. Remember it's HOT here. I live in Louisiana zip code 70508. And sorry seems to have a bit of a spike in the mid range.
also a little lagniappe for you.
https://www.youtube.com/watch?v=arlX2DfbLoQ
3rd gear pull.zip
  • Like 2
Just now, mr skidz said:
Borg vs -5 Internet racing championship.
*can't see ya rev gauge properly, I liked the other angle close up.
Looked like you stabbed it at 2k? Or 1k?
I'm on it before the video. I trimmed the video using the go pro (15 sec clip). I'm whistling because I was already on it and the car REALLY didn't like to be that low (I never have tuned full throttle from 1k). But I can put up the whole video if you want. The log is 100% complete and will back it up totally. I honestly have no reason to lie and I don't like to play in the 20-21 psi range because I'm still on the Haltech factory MAP sensor (internal only good to 22 psi).
Also on 255/40/17 hankook RS3's if that matters.
oh and another thing I noticed. The 3x diodes I put in the alternator sensing line really helped my voltage. Which also made my car too rich pretty much everywhere. I need to reset my dead times at 14+ V (hadn't been able to do that yet).
  • Like 1
Guest
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
