I'm also on the internal map sensor so that's why I don't like to run more than 20 at the moment I don't mind a little 2 pound spike over but I'll only hold it at 20psi at this stage.
every load cell has been tuned except for the impossible areas which never get seen in reality.
but while you have those recorded logs on the haltech it's a good time to go and address those load cells at 1000 RPM and up while you have the logs available I'll ask you are you running closed loop o2 control.?
for myself Im only using it for vacuum areas as soon as mine sees 0 PSI I switch to open loop and run off the map directly.
How you have yours configured makes a big difference on whether you can make those fine adjustments based off logs that's all
[emoji111]
  • Like 1
2 minutes ago, mr skidz said:
I'm also on the internal map sensor so that's why I don't like to run more than 20 at the moment I don't mind a little to pound spike over but I'll only hold it at 20psi at this stage. I'm at my car pretty anally so every load cell has been hit except for the impossible areas which never get seen in reality but while you have those recorded logs on the hell tech it's a good time to go in a dress those load cells at 1000 RPM while you have the logs available I'll ask you are you running closed loop au to control for myself I'm only using it or vacuum areas and like cruise soon as my a 0 PSI is detected I switch to open loop and run off the map directly.
How are you have yours configured makes a big difference on whether you can make those fine adjustments based off logs that's all
switching sounds like a good idea. I actually had pretty good results from open loop at first, but now I'm running full closed loop. It is a little frustrating in that you can get it perfect for fast shifting then it's weak on the low ramp or vice versa. The alternator voltage seems to have helped my fuel pump keep up with power (an issue I've been having), so I was afraid to try much leaning or boost until I get that sorted.You can see my request and actual outputs in that log (I think I have everything checked).
Keen (as you guys say) to see your results.
11 minutes ago, acsplit said:
Meanwhile I am very happy with my -5 3ltr setup and would not change it.
Now I am unsubscribing from this thread because of too many useless posts! :D
It sounds like it would be a great combo. Enjoy it. This thread is far too old and far too diluted to complain about, but I am trying to still provide what data I can to help those make an educated decision.
  • Like 2
56 minutes ago, mr skidz said:
That would be a torque monster!
Yep it is, pulls stumps good!
Ask Paul or Steve-o and that was before it made 370 rwkw @17psi on 98.
*I have now changed notifications to a weekly digest :) back to the EFR talk.
  • Like 3
Where have people sourced the correct Vband and clamp for the 8374/9180 compressor housings?
Treadstoneperformance (TRE) you can weld 3" on the inside of theirs and 3.5" on the outside.
3" assembly:
http://www.treadstoneperformance.com/product.phtml?p=68259&cat_key=613&prodname=Borg+Warner+EFR+Turbine+Housing+V+Band+Clamp
Both 3 and 3.5" flange:
http://www.treadstoneperformance.com/product.phtml?p=2542&prodname=Borg+Warner+EFR+Turbine+Housing+V+Band+Flange+3.5%22+Downpipe
I would not waste my time going 3" again
Nicks car just in.
-5's 424 rwkw at 24 psi
8374 1.05 462 awkw at 24 psi.
Same setup, same engine. 3.0, 9.0:1 comp, 260 poncams. No graph yet.
We don't care about peak power, how does it drive?
  • Like 1
Yeah that is not my RB30.
SR20DET built motor stock head.
EFR 7163. There is a lot of history in this car, I will update more when the owner gives it the nod. Should be tuned next week
Yes please. I have the TS 7163 IWG on SR20. Interested in others results.
Cheers
Guest
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
