On 8/10/2016 at 11:48 PM, VFRegal said:
Yes please. I have the TS 7163 IWG on SR20. Interested in others results.
Cheers
It is on a single scroll manifold I think and stock camshafts, solid lifter conversion to head, will be on E85.
  • Like 1
2 hours ago, acsplit said:
We don't care about peak power, how does it drive?
Only going off the info I had on hand at the time (an email that came through).  How does it drive? Can't comment on how it drives now but as it was said earlier, "un optimised" it was a significant improvement in every way compared to the -5's. That's been said a few times now though so it's going to be interesting to see how much it's improved again in its finished state.
10 hours ago, HarrisRacing said:
Treadstoneperformance (TRE) you can weld 3" on the inside of theirs and 3.5" on the outside.
3" assembly:
http://www.treadstoneperformance.com/product.phtml?p=68259&cat_key=613&prodname=Borg+Warner+EFR+Turbine+Housing+V+Band+Clamp
Both 3 and 3.5" flange:
http://www.treadstoneperformance.com/product.phtml?p=2542&prodname=Borg+Warner+EFR+Turbine+Housing+V+Band+Flange+3.5%22+Downpipe
I would not waste my time going 3" again
Nah, exhaust is sorted and am getting 3.5" made, was wondering about the compressor outlet flange, if you hack the end off its a vband, but not all v bands are created equal, (eg one my fabricator has bulk sets of has rubber sealing rings), just trying I figure out what people have used with success.
CC73D353-13A2-46CB-896D-95600D961DC0_zps
Thats what Hypertune did on mine, Pete. 2.5 inch to 3 inch 90 degree elbow.
  • Like 1
Careful...you will break down on the last lap of a race like Toyota at Le Mans when you use Wiggins clamps :)
Looks neat. A friend who has owned a few ex Gibson cars say that over time they can vibrate open so not a bad idea to just put a cable tie around them. Seems odd but i am not going to argue as mine are all hidden by diffuser etc and not accessible and be a head fark if they ever opened.
  • Like 1
On 8/10/2016 at 8:14 PM, Piggaz said:
Nicks car just in.
-5's 424 rwkw at 24 psi
8374 1.05 462 awkw at 24 psi.
Same setup, same engine. 3.0, 9.0:1 comp, 260 poncams. No graph yet.
Wind it up to 32 psi mate - should see 500-520kw :D
I'm gagging for those SR20 results. A fair few results on SR22DET or SR20VET or SR22VET.... but not much with a more 'simple' smaller cam, standard-ish SR20det setup. Would love to see what poncam, e85, t4 ts mani and EFR 7163 would look like (graph)
Ok here are some results.
SR20DET, forged bottom end, sold lifter conversion stock cams I think or maybe baby ones.
EFR 7163 IWG on old school manifold not sure if twin scroll, T4 twin scroll exhaust housing ( not sure of size)
E85 run in tune made 270rwkw @19 psi, 305rwkw@25 psi. Makes 16psi @3000 rpm and looks like it is a response monster.
I think the owner will get it back to shake it down before they lean on it anymore as it's a fresh motor.
Sounds good. Would love to know if you could confirm manifold and cams being used. Was expecting a LITTLE more if it's a T4 TS mani. SR20's do love a cam increase, so will hurt it alot if running stock cam.
Got a dyno sheet?
It was a manifold built 15 years ago so I doubt it is split pulse. No dyno sheet yet.
I also assume the ignition is very light on for this run in tune, also don't know how good the exhaust is as it's 15 years old (but has only done 5000 kms)
stock sr20, 260 procams, E85. TS T4 7163 IWG on fullrace mani and dump.
Boost issues.
Boost issues.
Dropping boost on top? Mine was on the medium cannister. It's almost as if these things should ship with high boost cans factory. Was cool to see my car make 376 whp on 11 psi though!
Yeah been a bit of an ongoing stuff around. FR shipped the wrong high booster cannister for TS frame. So then got a turbosmart dual port locally. It wouldn't hold boost. So changed EBC to one which can have different duties at different rpm but apparently made no difference on the dyno. Pretty much I don't think tuner likes the turbo :blink:.
Yep. No way to keep boost high enough on top end without changing duty cycle throughout rpm. Mine is almost linear on duty cycle for rpms after it onsets.
  • Like 1
Guest
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
