Another EFR faluire on EvolutionM forum. Im feeling sorry for the guys that've been waiting for over a year for there turbo to have this in the back of there mind - When i actually get my turbo will it fail. :(
I can say the car is stinking fast. First two sessions of the shake down run were great. Went out for the third session, hit the back straight and see a m3 passing me while at WOT. I'm thinking wait how is that even possible (Nobody could even come close to my backstraight speed.)Look down.... 0 boost and a supercharger like whine. Limped it in to see if it was any easy fix.
Luckliy I had the guys from RRE down doing track support so they checked and found no boost leaks and from the intake side it looks like the wheel started digging in to the inside of the housing. It SO hard to see. Running the car, There is a heavy metalic like whine, and with the intake off and putting your hand over the intake side it definently sucks... no leaks everything bulges like it should. The one interesting thing is that when you stop the car... the wheel just stops instantly... typically I was told on a BB turbo the wheel keeps spining.. this just comes to an abrudt stop.
So the car is headed back down to RRE for the turbo to be removed and inspected... But if it was damaged from the original issue, I'm wondering if that may have been part less then stellar results? I don't really know... but I'm trying my hardest to get a solution together before Tuesday.
So, the turbo is off and as far as RRE can tell the bearings are fine. The turbo does not spin because the shaft is bent. That is making it bind on the bearings. One sise of the compressor wheel has relatively undamaged blades. They do not contact the housing. On the opposite side of the wheel the blades are all ground away. We are pretty sure that it wasn't caused by the prior motor’s death.
To be continued:
Perhaps having such a distance between the bearing races isn't such a good idea then? - Wondering if the heat trapped in the housing is causing warping.
"the car is headed back down to RRE for the turbo to be removed and inspected... But if it was damaged from the original issue, I'm wondering if that may have been part less then stellar results? I don't really know... but I'm trying my hardest to get a solution together before Tuesday. So, the turbo is off and as far as RRE can tell the bearings are fine. The turbo does not spin because the shaft is bent. That is making it bind on the bearings. One sise of the compressor wheel has relatively undamaged blades. They do not contact the housing. On the opposite side of the wheel the blades are all ground away. We are pretty sure that it wasn't caused by the prior motor’s death"
ryan, i have spoken with this owner/driver many times over the last few days.. he has gone through (3) longblocks in 5 months. of course he had no filter in the oil feed line, so it seems possible the turbo might have received oil with pieces of oilpump/thrust bearing/piston fragments in it. FWIW on his brand new fresh motor he only got (1) lap in before the engine grenaded, and it was still fast enough to get him 4th fastest overall. The turbo is still good per his reports, we will get this turbo to BW for analysis - its possible the bent shaft assumption is incorrect and we will find metallic pieces inside of his bearing housing..
It's been an unfortunate series of events to be sure. Had BorgWarner known they were going to run into the production woes from their vendors they certainly would not have launched the product. Fact is, most turbos are holding up just fine. They have determined the culprit of those that have failed and all have derived from one vendor, and the problem only arose AFTER they were mass producing them. We have several that are in use now, taking plenty of abuse and no signs of failure on the horizon. I can say that the turbos we are getting now are solid, but very sparse. It will be another 7-8 months before these turbos are sitting on my shelf, in inventory, waiting for new orders. We see a lot of upside to these turbos, A LOT. It's just been overshadowed by production speed bump after speed bump.
completely agree.
Ominious.... hope this means the blue beasts heart will be getting a new friends soon:)
Yes...It's been on life support for almost a year :wacko:
I will have to wait for the manifold to be finished, as it has just been tacked at the moment to check for fitment, as the BW EFR is a bit different in shape, Then I'll get the manifold and the EFR's exhaust housing HPC coated, and probably the front pipe too.
....Oh and I have a RacePak IQ3 dash coming for it too....:banana:
Well.............
The Mythical White Elephant arrived today!! 9.5mths, It's been longer than making babies!
Serial number #13.....Hope it's lucky for me!
Thanks again to the guys at Full-Race (Geoff,Raffi,Brett,Aaron) for putting up with my constant emails, Just got to wait for the manifold to be finished, and some pipework to be built....Then it's tuning time!
Well.............
No worries mate. Good Onya! (that's about all I know)
Awesome Chris, hope all goes well for you - glad its at least finally here :) So what boost level are you tuning for again? Pump gas?
I will only be running 98 pump gas, So will depend on what the tuner manages to get out of it....Hopefully Lots!
I will change to E85 when it becomes available at the pump.
....Oh and the RacePak IQ3 digital dash turned up today! It's like Christmas!:cheers:
Guest
    • Hi guys looking for a r33 Gtst stock exhaust asap in Melbourne have $$ waiting thanks
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
