I really hope it's worth it scandy.
Remember back to the early release blurbs about how the integrated bov, boost control solenoid and IW housing options were supposed to make it easier and cheaper to fit one!
So do I mate. Got the bill from Andrew today for the manifold and all the rest. So far this exercise has set me back around $4k... Not bad for something that started out as $100 modify and replace project.
LOL ahh... cars.
"and all ill have to do is change this $5...... $5,000 part" lol yep.
I sold my last car and bought my current car complete, every mod I wanted. Now it only has scraps of the original setup left as nearly everything needed to be redone lol.
Keen to see your results tho, Its a nice kit up you have going :thumbsup:
Pretty well.
More shit. Car came home tonight.
Intake;
Starts at 3" and necks down to meet the 2.5" (?) intake. Trying to source a Pipercross filter with a Z32 mount. Then it's back to Andrew for any necessary mods, and to make up a decent bracket and close it off.
Lobster back hot pipe. Complicated little thing. 12 pieces.
Both will likely get coated wrinkle black to match the rest of the pipework.
And finally, the dump pipe.
I'll have to find a bung for the o2 port. Only there for tuning. I won't be running a sensor.
The dump, pipe, and cat are all 1 piece. So I only have 2 flanges in the entire system. Lovely.
Oh yeah, if anyone in here knows their wiring and SR's, specifically ignition, shoot me a PM.
This thread started 16 months ago..
I want a 8374. But I'm not prepared to wait for the next decade to get it..
What the Fire trUCK is going on..
Well i got my full race mani and BW 83/75 s300sx turbo in about 2 months, and it was only that long because the mani was made to order
Is there some sorta mad waiting list for the EFR's?
production issues actually, havent you read the thread start to end?
no point being interested if you havent
Yea righto mate
I've read the thread and know there's issues, just can't believe there's still a massive wait on a turbo that bearly anyone has..
There's was meant to be a "still" somewhere in my last statement :thumbsup:
lol i guess the 'still' would change everything.
i would assume BW arent in a big rush to roll them out anymore because of the prior issues. they are more likely to provide to a smaller client base for testing (workshops/race teams).
these are still on the map for me but as selfish as it is i want to see more results that show they are more phenomenal than the competitors.
Its very frustrating.
I've wanted one of these since I heard about them..
My other options BW s300 8375.. Bullseye S362 (virtually the same thing) or a gt35 with divided t4 housing.
All of which are proven performers.. And are all roughly the sme money delivered to my door..
Just not sure which would be the best on a daily street driven 1.5j.. :blink:
Just saw this too.. New for 2012.. looks like it could be a better option.
http://www.full-race.com/store/turbos/borgwarner-airwerks/borgwarner-s300sx-fmw-turbo.html
Edited by --Redwork--
Awesome, keen as to hear how that goes... Whats the rest of the setup?
2.6
Ross crank trigger
Link ECU
aftermarket ignitior (cant remeber what brand) need it to run with Link
sard 800s
Full race twinscroll manifold
260cams
Koyo intercooler
Jun pump
adj cam gears
4 inch dump with high flow cat into 3.5 rear
Both the 83-75 and the FMW are excellent bang-for-the-buck, great power and incredibly reliable. The FMW turbo is basically the "new for 2012" version of the S300SX 83-75. it uses an EFR 8374 compressor wheel combined with 2 different blade shape turbine wheels depending on what the application is. here is a photo of the comp wheel:
our customers who cant wait for the EFR 8374 are generally using this turbo
Edited by Full-Race Geoff
So benefits in response and top end in the new wheel design?
Can it be bought and swapped into a 84/75 housing Geoff?
Looks cool to say the least
The S300 FMW shares the identical turbine housing to the s300sx 83-75, 84-75 and 88-75, so yes you can share the turbine housings. the compressor housings you can not swap however.
if you decided to get one, i would suggest to get it with a different housing A/R and different blade shape than the turbo you currently have. the reason is that BW balances the non-BB turbo components individually, this allows you to mix and match between turbine wheels and housings on your turbo, without the need for a rebalance. these S300 turbos are extremely easy to disassemble and swap a turbine wheel on, just 2 wrenches on a left-hand-thread is all it takes
So to confirm iI could keep my turbine housing but I would need to swap out the compressor to match up with the new wheel design?
Is there any back to back testing of the old wheel design vs new?
BTW id be keen to do some back to back testing of the new wheel if i was to be supplied with one :whistling:
i got one of your Full race manifolds as well :thumbsup:
Edited by GTR_JOEY
So the compressor housing can't be swapped because the inducer size of the wheel is bigger... Yes.??
Comparing the 2 compressor maps it looks like the new wheel moves more air even at low boost levels.. But I'm no expert at reading comp maps... :wacko:
You keep your existing turbine housing but its a new CHRA.
The compressor is different and uses a different housing to suit, yet the turbine can use the exiting 75 housings despite being different.
My take on it is you can buy both the front and rear wheels along with a compressor housing and put it all together yourself.
Guest
    • 90lb/min @ 20psi is wonderful, not so much of a problem with the G35-1050's compressor efficiency (aside from how bad they roll back at higher pressure ratios).  The issue is more to do with the turbine's flow, which is why I'm not sold on going an even higher flowing compressor with the same turbine.  I'd say go back over Motive DVD's testing of the G35 1050 and Hawkins's comments regarding exhaust back pressure issues with it, I'd need to go back but I have in my head he went to the biggest hotside and ended up sacrificing a lot of spool (so it ended up behaving like a bigger turbo) and still had EMAP issues.  I've heard various other experiences along the lines of that. At this stage at least I rate all I've seen about Xonas (for transparency I've not used one directly, but I have spoke plenty with people who have) to have low exhaust restriction for the response they offer for any given setup - basically they allow the engine to breathe, which is good for the engine and makes making power a lot easier.  You arguably don't have to even push quite the same amount of airflow through an engine to make the same power if you don't have the bum plugged up with exhaust gas struggling to escape the engine due to an underflowing turbine.   In terms of reliability, to be fair I've had great luck with Garrett turbos as well - my GT3076R lasted forever, then I sold it and the next owner had no issues, then that car got sold and it was still going strong last I ever heard about it.  The trick is with the old GT-series turbos the compressors etc were no way near as efficient as what we have these days, it was almost hard to push them into severe overspeed situations without having a boost leak or something - and that is what often starts the failure situation.    In terms of your G35 I'm pretty sure you're running yours within sensible limits, something people with Xonas and Precision turbos aren't often so inclined to do.  The "compressor maps" are "Joe blogs ran 45psi through his 6466 so I can do the same" and built their setup to send it to the moon.  I've seen EMAP and compressor speed data where people have actually set that stuff up on Precisions and Xonas which have been run hard and the comp speed numbers are very very exciting at times - like I've seen 76mm Precisions run at rpm that you ideally shouldn't run a G35 1050 lol.   I know people who have run G-series Garretts hard and hard a failure, then replaced them with Pulsar turbos as a cheap "get it going" stop gap with the intent of doing a proper upgrade when THAT fails... and are still running the same thing.   Like anything, ymmv and it's not always to do with the quality or trustworthiness of said product. I've been provided with a bunch of compressor maps for Turbosmart turbos and will update my list based off that, they could prove to interesting reading and an interesting alternative as well.
    • Just cage it, call it a race car, and then fall in love with the chirp chirps through pit area!   Also, this is coming from someone with a completely locked diff...
    • I still have an old R32R left over from when they were a thing in the early 2000's. It was, for its time, done about right. But its time was 20 years ago.  I did try and update it a while back but it was cruelled by a (recommended) muppet of a tuna who couldnt tell his MAP from his TPS. The original spec was: Power FC, 700cc Sards, Nismo pump, 2860-5's, cams (Basically Poncam A's), Z32 AFM's and a half sorted oiling system. Thereabouts 430rwhp irrespective of what was done. So, yeah, very 1990's. I eventually got sick of it not being very refined and bought a Link G4 PNP with some 1000cc Bosch injectors. This was tuned badly and I put the car in the shed for a few years whilst I sulked and went and did other things. Ive come around to the idea of getting it going again so it has a new gearbox installed and some other minor things in the planning. So my questions are, variously (In the context of keeping the Link) What other sensors should I be running eg It has no wideband on it at the moment, nor fuel pressure. $? Is it worth chucking the old ignition system (ignitors etc) for new ignition coils? $2k? Cam/crank angle sensors? Can keep the aircon? $? Anything else? Sorry to launch another what should I do with my car thread but, you know, what should I do with my car? Random photo for historical context.
    • If you think that's harsh, go experience a KAAZ 🥲 Thoughts and prayers for Dose. I had mine modified by a diff shop to make it less brutal, no idea what they did but it's not as brutal as before. The Asian in me was being tight before and went KAAZ instead of a Nismo, lesson learned.
    • From what I understand, the normal Nismo diff is a bit harsh, and the Pro is the one that behaves more nicely, and you only pay Nismo tax twice to get it.
