You keep your existing turbine housing but its a new CHRA.
The compressor is different and uses a different housing to suit, yet the turbine can use the exiting 75 housings despite being different.
My take on it is you can buy both the front and rear wheels along with a compressor housing and put it all together yourself.
Righto cool, thanks for clearing that up
I could keep my turbine housing but I would need to swap out the compressor to match up with the new wheel design?
you could keep your turbine housing. You would need to swap out a "Supercore" which means everything except the turbine housing. Once you had this supercore, then you could swap back and forth turbine wheels with your existing turbo.
So the compressor housing can't be swapped because the inducer size of the wheel is bigger... Yes.??
that is correct. the compressor housing can not be swapped because the inducer size and the blade aero shape are different. Also - the bearing housing is needing to be swapped due to the 0.4mm difference in OD at the back-disc wall. For this reason, purchasing a complete turbo or a supercore would make the most sense.
The compressor is different and uses a different housing to suit, yet the turbine can use the exiting 75 housings despite being different. My take on it is you can buy both the front and rear wheels along with a compressor housing and put it all together yourself.
close... everything you said is correct except the last part
Please clear it up if you could, as my understanding was formed on your comment about put a spanner on it and thats it. As you said all parts are balanced individually
  • 3 weeks later...
Bit of a thread dig.
any word on the street about the reliability issues being resolved yet.
And Im looking at the EFR7064, but is it possible to be had in an open T4 turbine hosuing, Im looking at using a cast manifold that has an open T4 flange
like this
ufortunately there is no way of welding a divider into the collector :(
No T4 opens AFAIK Zeeb and I have been doing a little revision on these lately, but PT and Garrett would have you sorted (can get T4 open prints from GCG for the GT30-35 range).
Yes....
...but
Will it choke a 3L at 7000rpm?
Will have to attempt to find some results, but I doubt I will find anything for either the 7064 or the 5557 on anything bigger than an SR/4G/EJ etc
edit...Found a guy with twin 5557s going onto a 3.4L JZ :blink:
1 car 27 differnt plans for it lol
-5s = too much $$$ to rebuild + flucking about making oil waters lines fit :(
Im going to have to buy another Supra.....1 to put the auto + big bloody turbo in, and the other for a 5 speed and small turbo :(
anyone have a JZA70 they want to donate? haha
I am daily driving my Evo at 28psi, beating the snot out of it 4x daily. The EFR 8374 internal-WG twinscroll turbo has not skipped a beat
Also my RB26 nissan is ready to race, with EFR 8374 1.05 and external WGs i am dynoing thursday and racing saturday. 529368_10150632701911129_575236128_9575004_1038506751_n.jpg
turbokit:
wish me luck!!
Edited by Full-Race Geoff
Geoff - I thought for some reason you were going 7670 on the EVO?
What fuel, boost etc are you going to push the S14 to? Very keen to hear how that goes, good luck sir... it'd be nice to finally start hearing nothing but good results from these things.
DO show the dyno sheet please also any of the smaller EFR jobbies on a 3L (2J etc)
no problem, ill post it up. im using a stock bottom end r33 rb26 with jun oil pump and uprated rod bolts. ported head with stock size ferrea valves and tomei 280 cams, magnaflow 4" catalytic converter not gutted, Full-Race manifold recirc'd external wastegates and efr 8374, twinscroll 1.05, E85 from a local taxi station. im going to test it without catalytic converter to know the difference, its nice to not smell exhaust fumes! Also there is a 7670 1.05 on stock 2jz dyno chart ill post up
Geoff - I thought for some reason you were going 7670 on the EVO? What fuel, boost etc are you going to push the S14 to? Very keen to hear how that goes, good luck sir... it'd be nice to finally start hearing nothing but good results from these things.
i initially had a 7670 external wastegate going on my evo, but at the last minute a friend "leetevo" from evom needed it to make a race. i was able to get an 8374 internal wastegate turbo instead which worked out great because Im testing out our new internal wastegate AC compatible evo turbokit myself, daily, im stoked :) The 4G63 is a great engine.. and the car turns so quickly its remarkable, great street/track car, but to me the RB26 is something else and exhaust note is intoxicating. i find myself wanting to only build RB26s there is no other engine/driveline im as passionate about. it weighs a ton. its hard on front tires. difficult to get parts for. some people tell me the platform is weak... it cant change direction like a miata i really dont give a damn she runs hard!! super excited to be racing against a tweaked R32 gtr, apparently the guy expects to win the race this weekend.
Speaking of twin scroll EFRs on 2JZs, heres an interesting dyno comparison - twin scroll EFR8374 maxed out on E85 on a Supra, compared with a PT6266BB (single scroll) doing the same:
Tuner says intake air temps and exhaust manifold pressure were lower on the Precision turbo.
Guest
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
