Any idea on the cam/head specs on that 2j lith?
So full boost at 4k is rather good for a near 800hp
I wonder how much sooner the 6262 would come on?
The 2J is mental, its a 3.4litre stroker running an angry head and 9.5:1 compression - good motor to get the best out of a turbo.
Slightly OT, but from the same car the initial test was a PT6266 vs PT6766 vs a PT7175 - they just maxed out all turbos and posted the results:
SP have also tested a new PT6466CEA which the results for are flabberghasting. Looks like a fricken awesome unit for a street 3litre.
Naturally the power delivery and power levels are mental because of it being a big angry 2JZ - but its all relative. The EFR8374 is known to spool similar to a GT3582R, so the PT6266 etc are very very impressive for the power they make.
Stupidly responsive for the power output!
Yeah but have a look @ the power band, the EFR noses over after 1500rpm (4000-5500rpm), where the Precision pulls for a solid 2500rpm (5000-7500). Numbers are rough, but ya get the picture
Depends on the use of the car. Also Precision not being twin scroll as well... Very interesting comparo.
I assume it would be their 7 sec street/strip Supra motor for the big 1000hp runs
Was reading the full thread on SF earlier
We set out to prove the R14 conversion kit, ETS-Pro and EFR turbo today. using the EFR 8374 on my RB26, we got 1st place on the dyno - 704whp thru the cat, with huge area under the curve. This morning we also got 1st place in autocross (historically our worst event since we usually focused on drag and time attack) but a bad cyl #6 coilpack overheated in the back of the valley and ended our day. too bad, thats racing!
mr lith - here is a cell phone vid of the dyno pull from one of the guys who worked at the dyno shop, you can sort of see the chart at the end. the cat was glowing bright red
Edited by Full-Race Geoff
Guest
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
