My 6258 got pulled off the other day. Still in excellent condition after its first 17psi track outing. :)
Should have everything back together soon, then back on the dyno without an air leak... Hopefully.
Still looking good. :)
Turbine housing and exhaust manifold have both been ceramic coated, flange surfaces on the inlet manifold have been machined (3 of 4 were out of tolerance apparently), oil drain will be rectified next time I have a day off. Then I'll slap it back together, and it get back on the dyno, hopefully, with the mystery air leak sorted out.
Tha coating looks great. I'll do that on mine for sure.
I'm just REALLY frustrated about which one to get. "over-revving" these turbos seems to be a big no-no which sux because a 6258 looks ideal for awesome response on a 2.15L SR20 but even though I'm happy to run it down to 60% efficiency up near rev limiter, it's going beyond the "recommended" RPM. Not interested in th 6758 at all. It's compressor map looks horrible and the 7064's inducer is smaller anyway.
I just wish turbos were more customisable. I think the 70mm compressor model should also be offered with a 61mm turbine for smaller engines and a T3 divided .82 housing as well to fill the gap between the T25 .64 and the T4 divided .92/T3 .82 (both spool about the same).
What are the RPM limits on the EFR's?
That looks real clean. Who did the coating and what did it cost for the housing?
So get a 3071?
Anyway, i was at a track day recently and another s13 was out there with a .64 6758.
Basic built red top, 260/12mm camtechs, greddy intake manifold maybe and a high mount manifold. The thing was making a touch over 300rwkw at 21psi all in by 3500. Cheating with E85 but still very impressive.
I certainly wouldn't discount them.
So get a 3071?
3071R is bigger that a 7064. I want smaller. I'd use a 7064 over a 6758, even if I lost 150rpm of spool (which is all the dirrefence would be) in exchange for 10psi less exhaust manifold pressure and and extra 30kw up top. Makes for a way safer setup. It just annoys me that one must choose between a T25 .64 turbine housing and the next thing up is a T3 .82 with nothing in between. A T3 .82 divided housing for the 6258 through to 7670 would be just SO WINNING!
  • 3 weeks later...
E&H Motors in NZ have just released results of their testing with a twin scroll GTX3076R versus a twin scroll EFR7670 on their 2litre STI track car - worth noting that these results are not "all in", they have a stronger motor which will be used for that in future. From what the owner/tuner says it seems the EFR is much nicer to drive, and it sounds a bit like the EFR was seeming more eager to keep making more power.
Dyno plots:
I think it was just that they were aiming for an EFR7670 from the start, and ended up getting a GTX3076R to get going because of the huge waits for getting an EFR - or something to that effect. The test wasn't to because they were doing a shoot out, more just a result of having both turbos.
I know they've had a twin scroll GT3582R as well, I might see if they ever tried that on the Subaru....
Seems the EFR turbos don't need E85 to make good numbers - another Kiwi lad had his RB30DET R32 GTR tuned running a .92a/r twin scroll EFR8374 today on BP Ultimate, 462kw @ hubs on 20psi... full boost by 3300rpm.
Not too shabby!
Nice!
If only using one of these turbos was realistic. Waiting forever and having a questionable lifespan is very off putting.
Not that Id be at all interested anymore, owning a T3 6boost now -_-
Very nice! For the SR20? What trubro is going on it?
The life span of them don't seem to be a problem since the foundry change, I actually know of a few people using them - a 550whp STI I know has been using a 7670 lately with no issue, an EVO track car over here has also been using an EFR8374 and it has been performing excellently
Yeap for my SR. My DET block is down at the machinist right now, im waiting for a call to tell me what size slugs to order.
Having done as much reading as possible into readily available options I couldnt go past a simple TD06. The FP 73HTA wheel apparently needs a bit of energy to be turned and isnt likely to be as responsive as the old 20g item (more or less making it useless for me as I want 270-300kw). I also found a number of resources from people saying they had owned 3071 and TD06 SR's and found the TD06 to be a lot better matched.
So yeah, logical deduction lead me back to a simple kando TD06. $560 later and its crackin.
Sorry peeps, back to BW EFR :)
I wouldn't have (don't think I did) ever suggest the 73HTA for yours anyway - I reckon a 68HTA would have been great. I also lean towards TD06-20G vs GT3071R as well. Shame BW aren't doing EFR6758s in T3 though, I reckon one of those on an SR20 would be mental.
Guest
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
