Going off the position of the povit, being closest to the turbo. I'd say that is exactly how it works..
Be intresting to see if they become available to the public.. And what they cost..
Pitty they seem so large though..My turbo would be all most rubbing on my bonnet with that fitted under it.
Just like this :)
Sorry the link has pretty rubbish pics.
http://www.dieselpow...3t4-flange.aspx
Google turbine diverter valve for more images.
Edited by --Redwork--
  • 1 month later...
Looks nice, looking forward to hearing how this goes - what is the engine spec again? Is it being tuned on pump gas, or something alcoholic?
It's a Tomei 2.8l running 87mm bore,9.3:1 comp on E85. Has all the goodies to make the power.
Oh that's right, it all comes back to me - hadn't they (they being since demised units) already been run up and outspooled and outflowed the GT2871R-10s, at least while they lasted?
That's correct although I'm hoping these ones hang around a little longer. Wasted money on coating them if they don't.... :wacko:
They look like a pain in the ass to fit :(
Any reason why you didn't use a mettalic bend off that front turbo instead of silicone?
They become easier the more you do it....
No, other than when we first put them together we were under time restraints so just went with what was easier. Just using the same over this time again...
  • 1 month later...
Have you had a run on the dyno yet to see what power you got out of the new turbos?
No not as yet. When it was obvious we weren't going to make WTAC we took our foot off the pedal. Should be running in 2-3 weeks.
  • 1 month later...
I've set a time limit of end of November. If there are no 7064 .92's available, I'll get a GTX3067R with an ATP divided .82 housing or a Tial .63. Full Race should have T3 .82 7064's in stock now with T4 1.05's due in about a week and T4 .92's due about a week after that. I'll believe it when I see it.
  • 4 weeks later...
Happy to report back after my tuner has had a good play with the info from it.
It's just an optical sensor like the crank trigger.
A friend of mine has just installed the same on his RB, it was a first for Haltech apparently. Haltech spent sometime with both Ross and the tuner involved and loved the info from it. I believe they are going to write it into all their ecu software from now on.
i feel the same way. fortunately we've got tracking numbers now so the situation has improved
Just logged in to see if anyone has gotten the 7064 yet.
regarding 7064: the t3 singlescrolls have good availability, t4 twinscrolls shipping again
Happy to report back after my tuner has had a good play with the info from it. It's just an optical sensor like the crank trigger. A friend of mine has just installed the same on his RB, it was a first for Haltech apparently. Haltech spent sometime with both Ross and the tuner involved and loved the info from it. I believe they are going to write it into all their ecu software from now on.
good to hear things are working for you john, eager for you to get some seat time and finally experience the turbos at full song. btw did you guys get the ets-pro going
Edited by Full-Race Geoff
Guest
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
