the car we've been working on is the keeper's R34 GTR with 2.6L and twin 6258s (this is not a high reading dyno)
We also have an R34 and an R33 getting the same kit on 2.8L engines over the next couple of weeks. The only r32 gtr @ Full-Race is the front clip I bought to use for mockups.,, Perhaps you are thinking of Danh Tran's carbon R32 time attack machine? he is under the gun prepping for WTAC right now: https://www.facebook.com/danh.tran.10
Before the keeper's efr6258, he had -5 twins.. we tried many different piping configs and i dont see how its the pipe design that causes the shuffle... but if your experience got rid of it then great.
Sorry to bring this up again... I'm curious what size of intake filters these cars were able to fit. Twin 3"? 3.5"? 4"?
They appear crowded in so I wonder how much intake piping they could fit.
From this thread: http://www.skylinesaustralia.com/forums/topic/341890-borg-warner-efr-series-turbos/page-50#entry6409057And a later update for the same car with a stiffer spring and retune, still on pump gas - 470kw:IMG_1062.jpg Build thread: http://www.gtr.co.uk/forum/1760881-post678.html
Here's a quick vid of it running, sorry for the sh1t filming, I'm still learning how to use the camera
  • Like 1
Unless I can trade my existing manifold I'd be going T3, I just have a good bolt in kit I want to use.
ill see what comes up in the lead time :-)
one option you could consider is to run the 7670 with T3 turbine housing initially. Then, later on if you wanted to go twinscroll - just swap to a divided manifold and a divided housing
the twin turbo kits use B1 EFR turbos. these all have 2.5" inlet. You can step that up to 3" if you like, but there is zero benefit to 2x 3.5" or 2x 4" on a twin setup
sounds healthy
Well I just pulled the trigger on a full race 8374 1.05 setup with manifold and twin 44mm gates so here's hoping it's everything I hope it will be!
thats my favorite combination ive run on the RB26 over the years, you wont be disappointed
Love the video! Are you able to rev it a little more so we can hear that turbo spool a little (understand if you dont want to) smile.gif
Edited by reaper
external wastegate ; is it still civil for street driving ? or too loud?
Screamer? I suppose everyone has their own view but its way, way too loud. Everytime you give it a bit you have to listen to that - No thanks!
I agree. IWG and No/recirc blow off valve is best for street unless you're into that stuff. Then again, my PPG dog is louder than my exhaust....
But I'd guess the EWG is best for track car.
If your car is mainly street (and even more so if its your only car), keep it simple. IWG
I wish BW'd get the finger out with the B1 7163 turbo because it's been soooooo long in the pipeline . I keep searching for new info/results but all I find is limited testing with prototypes and they've changed over time . About the only thing I've read recently is that they (I think) developed to be in step with Indycar apps and possibly that held them up . I'm guessing the "little" extras like the aluminium centre housing and the mixed flow turbine wheel have gone through the competition R/D wringer .
Anyway if you see GT3076Rs as the yardstick to measure RB25DET turbos with then the 7163 should do anything they can and in theory be better everywhere , except packaging and cost .
Being a B1 cartridge size these may or may not get the 0.83 AR T3 flanged single scroll IW turbine housing like the B2s do . There is supposed to be a T4 twin scroll IW housing for them but not sure about T3 . It's hard to say if there is sufficient call for an open T3 IW B1 housing though BW obviously thinks there is for the larger frame 7064 7670 etc .
Anyway if the 7163 really can smash everything up to 500/550 Hp whilst being light and reasonably compact , at least diameter wise , BW should clean up .
The market has waited so long for these turbos and you have to wonder what other turbo manufacturers are brewing up behind closed doors . You can wait too long and many have given up spending their money elsewhere .
Alas, don't expect logic to dictate success. FP have been making turbos for 5 years which outperform the the GT and even the relatively new GTX range by a margain and they are still hardly considered or used ... at least in this part of the world.
If you believe the chest puffing, Garrett are getting nearer to releasing their gasoline dualboost technology and potentially will move the bars for performance expectation for mid size turbochargers.
Guest
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
