Not as yet I only received it this week! I plan to put it on in December as I have a few other parts I need to collect to upgrade the fuel side of things at the same time
I'll take some photo's when i'm doing it all if you would like :)
I'm interested to see how they added the VQ35 hydraulic cam actuator to the front of the camshaft and got it all to work.
My VQ25 runs an electric clutch CV arrangement instead, which may be easier to retrofit as it doesn't need the hydraulic lines. I always wondered why HKS went the external oil feed path... If you could post pics in a Vcam thread I would appreciate it.
Should be a great addition, but I hope you have the valve clearance. Those actuators can advance 50 degrees. Who will be tuning it?
Oh sorry I thought you meant about the turbo install.
I actually bought the car with the vcam already installed. It's currently running the the vcam controller and an fcon v pro which i'll be keeping for the time being.
Will be retuned on e85 with the new setup and will more than likely be done by tunehouse (fairly limited when it comes to tuners that can tune an fcon and vcam)
It will be more responsive and make more power. Everywhere. A guy on NS put a 6758 (bigger) on his SR and it was a bit like a V8 in terms of delivery.
Wait for the 7163, that might be a game changer.
If I got the 6258 and a manifold to suit, would would I have to convert the rear housing to a t3, or is it feasible to run a t25 housing on an rb? i.e. too much of a bottleneck not enough room etc.
No it will be fine. The best thing to do will be to have a good fabricator cut off the T2 flange and weld on a nicely shaped reducer and a T3 flange.
The housing is stainless so you can weld on a stainless T3 flange no hassle.
Read the last 5 pages of this thread as we have been discussing exactly this (i want a T3 7163).
Also, is go a bit larger and get the 6758 or 7163 as the 20s like to rev :-)
  • Like 1
New turbine/housing options listed on match bot too.
Also found an awesome read on mixed flow turbine wheels with a mention of the pros/cons of using TiAl - http://www.hindawi.com/journals/ijrm/2012/589720/
Needless to say, I'm very excited about the 7163 in 0.80 twin scroll (although I hope the 0.80 comes out for my 7064 because I'm not changing turbos any time soon)
Guest
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
