I personally think that I would prefer an EFR8374 on my car. In saying that you couldn't really ask much more from the PTE 6262, 710rwhp is crazy and response is very good.
The main thing that turned me off the EFR was the physical size and lack of housing options in external gate, in fact if someone can show me one will fit between my strut tower and my motor, plus a T4 divided in a 0.8 rear and I'll give it a go
I have my 8374 fitting between the struts in my R32, and it has the T4 divided .92A/R IWG housing so it's even fussier to fit. Yeah it's tight, but no issues. You wouldn't want anything smaller than the .92a/r on an RB26 or RB30.....it's borderline too small on mine, I could still fit the A/C pump back in if I wanted......but I'm reserving the space for a dry sump pump one day :-) Edited by Sub Boy32
You arent using a full race manifold then I guess? My full race manifold put the turbo quite a fair bit forward
No, I had Sinco Customs make me one, it's similar to their TO4Z manifold, but has been lowered to suit the extra height of the RB30 and the size of the EFR.
With the EFR7064....in T4 TS 1.05 A/R configuration
Would this be enough for insane response, broad power band and 8000rpm redline on a 2.0L or 2.2L SR20 (with correct cam selection) while pushing over 400rwhp?
My goals are to find a turbo which will support my goals of a very fast street car (in all aspects) which will also be brutal on the circuit...
The newer 7163 should be superior, both will support more than 400whp on E85.
Want to keep it on 98 octane....
I like the idea of dual external wastegate T4 twin scroll.... which the 7163 doesn't have.
The 7064 seems (t4 ts 1.05/ar ext wastegate) seems as though itll have more top end potential whilst retaining savage response...
The 1.05 is prob a bit big. The .92 easily,easily will achieve that goal. I have a 2.15L SR20 with a 7064 .92 and Poncams (tiny) and mine made 258rwkw on about 16psi with very,very conservative timing. It goes a lot harder now but haven't dynoed it since. Still can't afford to take it in for another run. With 24-26psi and 260 degree Procams, it'd go off it's head (Prob 350 odd rwkw. My injectors/gearbox/clutch would not support that level of power).
Edited by bradsm87
Awesome to hear Brad....
What RPM are you achieving full boost and what is the transient/throttle response like? Is the acceleration fairly savage as is and what is the car like for spirited driving?
I hear the EFR's well and truly come to life when high boost is pushed into them.
Full boost at 3300 if loaded up in a high gear from low RPM. Transient throttle at anything above 3700 is insanely, insanely quick on to boost. Comes on gradually and very controllable if loading up from low rpm. If u hit the throttle at 4500-ish, u gotta be careful becomes on very fast and hard.
Been wondering if it's physically possible to fit a 7163 onto a RB25 stock manifold.
I make out that a GT3071 is about 150mm from face of flange to furthest point on compressor housing. The 6758 (which I understand is outline identical to 7163) is about 165~170mm in T25 form. Possibly even bigger in TS T4 format. Given you would need a spacer to fit the 7163 (to convert to T3), it's probably 20mm or so closer to shock tower...
Anyone know how much extra room there is in R33 GTST engine bay with GT3071 / GT3076? Would one of these EFR turbos fit?
Pics below of references. I made pretty agricultural measurements assuming the pics are to scale.
Also for s#!ts and giggles, I overlaid GT3071, GT3076 and EFR 7163 compressor maps.
Notes:
Efficiency island:
GT 76%
EFR 74%
Speed lines:
GT 120k
EFR 110k & 130k
The 7163 looks pretty damn impressive. Thoughts on how spool time would be compared with GT3071?
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
