20 degrees is listed as max angle of tilt for most all turbo mfg's but i always keep it under 7 degrees on all the setups we do here and usually 0 degrees
tonba -- tial is developing housings that are more compact for the EFR turbos. If you are interested in a compact version, let them know what youre looking for - they are asking for input during the design stage on what turbos to offer their versions of first
  • 1 month later...
So one of the drifters in NZ just replaced his old T04Z with an EFR8374 (with 1.05a/r twin scroll housing) in an effort to improve response without losing any power... the car got off the dyno today, it's actually running a head that was previously used on a drag car and a big tube turbo manifold - so not necessarily the most conducive to good response - but nonetheless an interesting comparison.
General specs: Built RB30DET with 272deg cams, LOTS of headwork (initially used for >1000hp), twin scroll Sinco exhaust manifold, 1.05a/r EFR8374 (replaces the .70a/r TS T04Z that was on). These dyno plots are for 17psi and 20psi on the EFR8374 versus ~22psi for the T04Z:
And Facebook post showing updates - all in it made "900hp @ engine", aka 610kw @ hubs:
https://www.facebook.com/zpdrift33/posts/658380957566507?stream_ref=10
So yeah, the EFR matched the 22psi T04Z run almost all the way through the rev range using only 17psi - and well and truly surpassed it on 20psi! Definitely a big improvement, and that's before the famed transient response which he'll get to experience in a couple of weeks on it's next drift event :)
Back when I learnt maths 610-510=a number much bigger than 30. When in conjunction with a few hundred rpm lower boost threshold, without bringing into question the thing the EFRs are most famous for - transient response, then yes... that's all :P
Oh my bad, I was only looking at the first graphs you posted. Once I opened the FB link I saw the 900ps run.
So 300rpm and 150kw. Interesting.
Transient response lel
here is another relevant Garrett vs EFR comparison (on an Evo) of these turbos "all in" with our twinscroll turbo kit. this customer is doing 1/2 mile rolling races, and wanted to use the same kit Sierra Sierra ran
GT4088R 1.06 a/r (dotted line) @40psi (dropping to 34psi)
EFR9180 1.05 a/r (solid line) @42psi boost (dropping to 38psi)
10003766_10152281695592527_1737921528_o.
  • Like 1
Perhaps they should look at a more compact compressor housing as well.
I would have considered a EFR8374 if it came in a smaller housing/external gate 0.8ish rear, front cover without the extra crap would be handy as well
  • Like 1
TiAL are going to be doing externally gated V-Band housings for them soon, no doubt they'll do a .82a/r version as one of their options :) You can get blanks for the BOV if you want to run your own, too.. so it'd be pretty much a "normal" turbo
What compressor housings do the Indy cars use ?
I initially though they were airwerks due to the fact the FMW compressor wheels are apparently the same wheels as EFRs.
But then I saw the pic of what they actually run, which looks to be a custom casting.
borg-warner-turbochargers-used-in-the-iz
Yep , many petrol heads will have the recirc valve and boost solenoid covered so extra bulk and clutter is often not needed .
If omissions like this make EFR turbos cheaper lighter and easier to package it's a no brainer .
I would prefer to see BW do this but if not the aftermarket may be able to cater for it if BW is prepared to sell their cartridges separately .
From memory EFR 7163 does not use port shrouded comp housings so simple all round you'd think .
Geoff , plain Jane B1 comp housing available - in aluminium ?
  • Like 1
This car had it's first drift outing with the EFR this weekend, running on it's lowest boost setting - here's some in car from the event: https://www.facebook.com/photo.php?v=667298030008133&stream_ref=10
Yeah, I think that is the best demonstration I have seen of how responsive those turbos are in practice for the power... Pretty awesome as that is near 100kw off its full power in that clip!
Sent from my GT-I9505 using Tapatalk
Here's some video of an RB26 with a pair of 62/58's on the dyno. It has 272º HKS cams, +1mm valves and some mild head porting. It's on E85 on a dynojet dyno.
You can get an idea of spool up by freezing the dyno graph. Figured any info is better than none.
Was just looking at the specs for those 62/58s bigger then a garrett 2860 in all forms... yet on full race site they have a dyno graph of it boosting earlier then a 2860rs... sounds like a good pick, probably only good for a modded motor
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
