Someone is paying attention!
Ok, how about WRC cars...
Well
the antilag setup works almost like a blow off valve
dumps pressure from the intake into the exhaust manifold
They were also rebuilding the whole car and replacing turbos after every event
  • Like 2
Alex, everyone has differing opinions and theories, and sometimes mine are well out of the box, but I also prove mine on many occasions by making it work and getting the results. My theories have yet to let me down in practice, and I help build quite a few high power cars for customers. No-one is wrong in any situation, and if your 'Bolt-on' approach is easier by all means go for it. Remember, there is always a better way though.
This bloke! :)
The whole point of the turbo speed sensor is so you can make sure where on the compressor map you are. Going outside of that compressor map is for people that have dyno queens, or run some sort of ice box for drags, as it superheats the air, reduces effency and increases chance of engine damage.
Borg Warner broke the existing turbocharger mold when it created the EFR line. One of the main goals was integrating other turbo system components into the turbocharger. This ploy can save time, money and headaches. The biggest integration is the inclusion of an integrated blow-off valve. No more bung welding on delicate intake pipes. The BOV is laid-out as a compressor recirculation device that redirects the charge air from the turbo's compressor outlet to a low-pressure point just before the compressor inlet, which really helps keep the unit spooled between shifts.
I think you mean innovation.
They haven't done anything amazing they have just allowed Joe Average buy a turbo with all the fancy stuff for a cheap price (in comparison to a real motorsport turbo that retail around $10k).
You keep reading of the catalogue you need to think about what the actual turbocharger is doing and what is happening to the air.
-sigh-
If you guys on actually care for all the technology offered in this package.. why bother for such an expensive turbo with barely any results... Why not just got for a proven Precision, which happen to make the light switch power your interested in, all for a low cost... AND no real mounting issues....
Oh crap, FP don't have compressor maps... Whatever would you do in that case?
The sky is falling... :P
Just ceramic bearing failures. :/
Been there tried that...
FP make good street turbos, and the best 'bolt-on' solution for a number of make and models.
But personally, I just don't know where mine is (on compressor map), which is why I run it on such low power on track. I just want consistent power. I think FP make great compressors, but it frustrates me they done provide compressor maps. Oh not to mention that it annoys me about the turbine side and dump pipe design...
You can hardly call FP in the same league as EFR, ESPECIALLY in motorsport applications.
I run Garrett and recommend them whenever possible.
What I am after is a cheaper EFR without the bling. I only want the turbine/shaft preferably, shoved into a Garrett GTX core.
If Garrett release a Ti wheel, BW will have missed their chance of a lifetime. No skin off my nose.
Why do you need a comp map....wouldn't a IAT/EGT sensor combo and a tune pushed to the limits of diminishing returns be enough to tell you if you are in its "efficiency zone"...?
Correct, and be much more accurate than a made up map to suit a made up application.
Every engine will behave differently, depending on what you have in the way of restrictions to flow. After all, boost is only a measure of restriction.
NONE of the alternatives mentioned are in that league though - so that doesn't really say too much. FP don't release compressor maps but there is enough info out there to get a reasonable idea of what the different compressors flow like where, definitely enough to get an idea of where each sit in the scheme of things, lack of compressor maps don't hurt Precision and to be fair I suspect 90% of people here don't really pay attention to comp maps or other related info and dynamics when choosing turbos.
FP have some epic turbos, Garrett also suffer the same lack of twin scroll housing etc stuff you are complaining about - funnily enough most of the same housing options are available to both. The FP Black is a pretty awesome turbo, have you actually had it running and tuned yet?
  • Like 1
Yes it is an awesome turbo. I haven't run it on my new setup, only my old 2.3L. We didn't run it too hard, only 23psi in which it made a very lazy 300kW on e85.
Spool was really good for a turbo its size, but transient response wasn't the best... Journal bearing turbo..
I am inclinded to agree. If I had my choice again I would have gone Garrett, but at the time they didn't have the range in the GTX series or the range of housings.
Oh you have the non-DBB one - for some reason I thought it was the DBB version. I've only experienced the 82HTA compressor in a twin scroll GT3582R HTA setup and that was really really impressive response for the power it was making, "only" a pump gas setup too making around 500whp (DD rolling road style) on a 2litre. GTX I feel is more miss than hit given how far behind Precision and FP they were in releasing their technology, most the FP wheels offer better flow versus response - though now they've raised their prices (when GTX came out the HTA were cheaper) there seemed pretty much no point bothering with the GTX range, though now if you want an HTA with a non-plastic bearing cage it's pretty expensive.
For RBs the EFRs are easily the best, they aren't particularly hard to fit big singles - not a lot more expensive considering the performance, and strong as anything... I find it weird that people have issues with the extra bits, they perform and save other bits of expense... especially if you are building a new setup. Not having to fabricate a place to fit a BOV, and buying the BOV in the first place definitely will save some coin and space and I don't mind the look of them, I reckon they look pretty serious business as opposed to yet another Garrett/Honeywell stamped compressor cover that could be anything from a T3/T4S up to a GTX3582R.
  • Like 1
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
