^ Further more...
I wonder if the compressor wheels on the Airwerks line of BW turbos can be interchanged for the EFR compressors.
EG - Purchasing a EFR8374, removing the 62/83mm compressor and replacing it with a BW 64.5/88mm compressor... The turbine side should be large enough to still power that size compressor??
^ You don't think BW will develop a 64mm turbo?
My response was moreso in reference to a hybrid thing of potentially mismatched technologies, althouth in respect of this question I would say no. I don't.
The current field feedback doesn't appear to indicate a void between the two that would necessitate a new product, particularly considering the smaller demographic at the target outputs. Most of the early comments (admittedly from the likes of FR) read to the tune of "go bigger, you won't miss anything".
Sometimes its good to roll back and have a second read of the thread to form a better opinion on this sort of thing. A varied knowledge base like what most full-time SAUers have leaves our opinions a little tainted, and I feel we may be searching for a 64mm alternative purely because other hot-topic competitor outfits have them. Correct me if I am wrong but even FP have jumped on the PTE sizing bandwagon.
Anyhows, such is another opinion.
  • Like 1
  • 3 weeks later...
Here I am again, I took 2 weeks to read the whole 94 pages..
Long story short : RB26 Head need a rebuilt, I was leaning toward a RB28 + billet 60mm on my twins ; A few friends told me it would weaken my block and would push the turbos to their limits = not so ''safe'' and reliable option.
They told me to stay rb26 and put a single... more reliable and the single won't be pushed to the limits., I like the idea, so I want a EFR!! :D
RB26 Forged piston + type-B poncam ( I could swap them if needs to be..), I would really prefer to keep my 3 inch exhaust ( it's quiet and cops never give me trouble). IT WOULD BE TUNED ON 94 octane + WMI (aquamist kit).
I want response ( I used to drive GT-SS and somewhat missed the quicker response the gt-ss had Vs. the -5s) and I reckon IWG 0.92 would spool quicker than 1.05 and would be a good load cheaper!
- Considering I only have acces to 94+ WMI.. I don't think going any higher than 26-27psi is recommanded, Agree on this ?
So which EFR, should provide me the best response/power at 23-27psi on a 2.6L ? is 81/90
83/74 0.92 IWG ? ( I would upgrade to the Turbosmart IWG EFR option) I'm hesiting because sub-boy did 640whp on a rb30 with this turbo.. so with 400cc less and 3 inch exhaust vs 3.5, should I be expecting approx. 600whp out of it ? or even less..
(without beeing a dynoqueen, I somewhat wished to break the 600whp marks ( I was at 573whp with my -5s), but ''transient response'' is still more important in my book than the bragging number)
Edited by cobrAA
I run both 8374 and 9180 turbos on my 2.6L engine, the EFR8374 is my call for a street driven 2.6L rb26... 1 bar by 3400rpm and so much fun to drive. The 9180 is a bigger turbo, comes on later and hits much harder. Regardless of this, the WG config will depend on which fuel you are using and your boost targets.. for a street car the 0.92 makes a lot of sense. i prefer the IWG because it is so simple and lightweight, but externals do have their benefits also
your 8374 is the 1.05 right ? so should the 0.92 spool a tad quicker then ?
As for your question, I said in the previous post, we only have acces to 94 octane and I added WMI, so I imagine 27psi should be approx. the max I could go without being in the danger zone.
thank you
1 bar at 3400 in 4th on the road? How about the 9180?
Videos please!!! That's almost enough to convince me to switch from my 6262 (if it fits on my manifold), in fact if I can make 700hp on a Dynapack with SAE2004 with a 8374 T4 1.05 and it makes 1 bar by 3400 I will purchase :)
thank you
Im switching back to 8374 0.92 a/r now. We have a new shop track car to focus on, so my Nissan will go back to being a fun casual project. Considering your boost limits and fuel, I agree the 0.92 could work well. Just expect the turbo to run out of exhaust flow around 625-645whp as opposed to 700-730 with the external gates and 1.05 a/r
compared to 8374, the 9180 came on song ~400-500rpm later. I can not verify fitment on other company's manifolds, but even on the older Full-Race RB manifolds the EFR will fit no problem. Just make sure its divided with dual wg for optimal performance. If a gt40R can fit it then EFRs can fit
here is a dyno video from a couple years ago when my car had 8374 1.05 a/r on a dynapack with R33 trans and catalytic converter:
Edited by Full-Race Geoff
I apologize for being annoying in advance :)
I rather save 1000$ish and put it toward a Quaife front diff ( my engine is coming out this winter). However, I also know, 6 month later, I will regret not paying an extra 1000$ to get an extra 75whp so I rather do it right the first time. ( At the same time, I gotta ask if 700whp ish isn't too hard for a standard 5speed gearbox..)
Spool : How much of a difference is there between the 0.92 and 1.05 ? Are we talking something like 150rpm or we're talking 400-500rpm ?
Power: I know the 1.05 can make 700whp, you did it, but you also had 3.5 inch ( I have 3 inch) and you have E85 ( I only have 94+WMI), so given the same 1.05ar , shouldn't I be more in the 650whp mark Vs your 700whp ? In other words, I'm unsure if my setup will be able to make ''full-use'' of the 1.05ar.
Thanks a lot! ( I rather write it here than PM so other can benefit from the answer)
I consider a good front diff a mandatory upgrade on an R32/R33 (stock is fragile) and even though R34's front diff is stronger the improvement in vehicle dynamics from a proper limited slip differential is hard to argue with
yes, 700whp is too much for a standard 5speed and wayy too much for a stock front diff. front diff will probably fail before the trans, but 3rd and 4th gear will let go too.
with the stiff actuator on the 0.92 a/r I'd guesstimate the spool difference to be ~200-250rpm due to the smaller A/R.
However, if a soft iwg actuator is on the 0.92 then they will spool about the same
since you only have access to 94octane fuel with water/meth you are not going to be making that kind of power safely. Pump fuel is such poor consistency from pump to pump that you can not safely map with aggressive ignition timing. I made 590 on my car with pump gas, I could have made more and pushed it harder but I think that is probably a good stopping point and with meth you can get into the low-to-mid 600 range.
keep in mind i was using an off-the-shelf catalytic converter, thats a big restriction. Admittedly we try to run E85 in everything since its easier on the motor to run high boost with some ignition advance
A mate on here went from -5's to a 8374 internal 0.92 rear. 5-700 rpm earlier it comes on and makes more power. Given that Geoff reckons the 1.05 will be 150-200 rpm behind the 0.92, you're still infront.
so it's a done deal. Buying a 1.05 :)
Btw, did your mate posted his result/comparaison somewhere on the net, I couldn't find any rb26 with a 0.92 from my research.
Will gladly post result when I have them ( in about 6 months considering where I live lol)
  • Like 1
Guest
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
    • Keen to see the turbosmart data, to date I've only seen negative things in terms of response for them. Very small sample size though.     Hawkins is a big advocate in his videos of the larger rear housings. I managed to make similar power with a lower spec motor on the smaller .8 rear, keeping decentish spool.  The people he works with now are big power cars compared to mine though, mine really is setup to drive around and enjoy.  I don't have any back pressure monitoring though, so couldn't say if its good or bad on my car, just that it does what I want it to do.   Future I want a higher compression more cubes motor to give a bit more bottom end and hopefully the new g35-1150 gets me to the 850 rear comfortably.  But maybe I won't due to exhaust back pressure.
    • No, I refuse to buy their cheap ass crap! I do need to order a bunch of different nuts/bolts to refill my nut/bolt wall though. Maybe you could go for a walk through Bunnings for me? (Or send me some stuff from your work? )   I really struggle to work out how the US standardised to Metric in what the 70s or 80s, and yet, half a century later, there's been little done to actually bring it into fruition. It truly baffles me    On the whole Fastenal thing, I went reading their site (My god they sell a lot of varied stuff!), and it seems like it really depends what store you're near if you can walk in and just grab a few small things, or if that branch is primarily distribution with only a small window of "counter time" available (if at all). That definitely makes it harder, as move locations and it drastically changes your ability for success   For things like your M6x1.0, if you want to work on your own Skyline, and you also have a "home workshop" I'd recommend setting yourself up a small Nut/Bolt wall/section. It doesn't even need to be big at all. Most things depending on the diameter, will be a specific pitch, like the M6x1, M5x0.7 etc. Bigger bolts is mostly 1.5, except for a small number of things and that will come down to torque. From memory bolts for the brake calipers (and other things that need a lot of torque) will end up being a 1.25mm pitch. Save up a few dollars, and order a range of nuts/bolts. If you want to minimise cost a little, buy something like M6 x 40, and M6x70mm (1mm pitch) in both. In addition, buy yourself an M6x1mm thread chaser. That way you have long bolts that you can cut down to size, and then chase the threads out. Funnily enough, I find what I'd pay here for ordering 5 bolts, I can pay about 50% more and you'll get 100 of them.   If that doesn't quite work out due to space / ability to buy plenty up front, then each time you need some bolts, order 100 of what ever you're getting. Put them in clearly marked containers. Over a few years, you'll acquire plenty of different sizes, and will end up ordering less and less. And the cost for 100 bolts won't be much more than you paid for your 5 you needed to order anyway  Just takes a little planning ahead, by investigating what nuts/bolts you'll need, and ordering them before doing the job.     Edit: If it's also primarily for working on just the Skyline, for some reason my brain is screaming that at some point, either Nissan, Nismo, (Or possibly a third party) was selling a "kit" of every nut and bolt in a Skyline, purely for people restoring/rebuilding. It'd likely be quite expensive, but would give you every/any nut/bolt you need for stock/factory things. I'm not sure if it's still available, or even if it actually fully came to market, it's just something niggling in the back of my brain that you could look into further if that sort of thing interested you? (It might have been for the R32 GTR or something specifically too, and not just any Skyline)
    • 90lb/min @ 20psi is wonderful, not so much of a problem with the G35-1050's compressor efficiency (aside from how bad they roll back at higher pressure ratios).  The issue is more to do with the turbine's flow, which is why I'm not sold on going an even higher flowing compressor with the same turbine.  I'd say go back over Motive DVD's testing of the G35 1050 and Hawkins's comments regarding exhaust back pressure issues with it, I'd need to go back but I have in my head he went to the biggest hotside and ended up sacrificing a lot of spool (so it ended up behaving like a bigger turbo) and still had EMAP issues.  I've heard various other experiences along the lines of that. At this stage at least I rate all I've seen about Xonas (for transparency I've not used one directly, but I have spoke plenty with people who have) to have low exhaust restriction for the response they offer for any given setup - basically they allow the engine to breathe, which is good for the engine and makes making power a lot easier.  You arguably don't have to even push quite the same amount of airflow through an engine to make the same power if you don't have the bum plugged up with exhaust gas struggling to escape the engine due to an underflowing turbine.   In terms of reliability, to be fair I've had great luck with Garrett turbos as well - my GT3076R lasted forever, then I sold it and the next owner had no issues, then that car got sold and it was still going strong last I ever heard about it.  The trick is with the old GT-series turbos the compressors etc were no way near as efficient as what we have these days, it was almost hard to push them into severe overspeed situations without having a boost leak or something - and that is what often starts the failure situation.    In terms of your G35 I'm pretty sure you're running yours within sensible limits, something people with Xonas and Precision turbos aren't often so inclined to do.  The "compressor maps" are "Joe blogs ran 45psi through his 6466 so I can do the same" and built their setup to send it to the moon.  I've seen EMAP and compressor speed data where people have actually set that stuff up on Precisions and Xonas which have been run hard and the comp speed numbers are very very exciting at times - like I've seen 76mm Precisions run at rpm that you ideally shouldn't run a G35 1050 lol.   I know people who have run G-series Garretts hard and hard a failure, then replaced them with Pulsar turbos as a cheap "get it going" stop gap with the intent of doing a proper upgrade when THAT fails... and are still running the same thing.   Like anything, ymmv and it's not always to do with the quality or trustworthiness of said product. I've been provided with a bunch of compressor maps for Turbosmart turbos and will update my list based off that, they could prove to interesting reading and an interesting alternative as well.
    • Just cage it, call it a race car, and then fall in love with the chirp chirps through pit area!   Also, this is coming from someone with a completely locked diff...
