I'm Setting up a fuel system with a surge tank and external pumps on my 32. I am just after advice on where to run the return lines. That is do you run the return from the fuel rail to the surge tank and a return from the surge tank to the fuel tank? Any advice on how these setups work is appreciated, thanks.
https://www.sau.com.au/forums/topic/341927-surge-tank-setup/
your feed pump would have to flow more than the main pump. which means you'd still need a return from the surge tank so it doesnt pressurise. apparently creates issues with pressure in the main tank too. run the rail return into the surge tank then return from surge into main tank, proven setup
