hey guys,
in the past wk or so, my rear suspension has developed a pretty loud creaking noise.
after some inspecting, i found that the rubber boot surrounding the shock absorber is pretty much shredded. moreso on one side than the other. it also seems to not creak when i drive in the rain. would it be my shock absorbers?
it mainly happens whilst going over bumps. like when entering a drive way, its a slow squeak.
is there something that i can lube up my shock absorbers with? just to eliminate if thats what the cause.
if anyone else has a different idea of what it could be then pls post to me.
thanks guys
Callum
https://www.sau.com.au/forums/topic/341956-creakkkk/
hey mate join the club,i dont know what's wrong with your shocks or springs...
i got a same problem as you facing,i took my car to the pedders in prospect area in adelaide..anyways they checked and found my cars spring not sitting right and rubbing against the body and making noise on every hump and bump...
so try to book with some suspension workshop or pedders and they will find the source of these noises...hope its helps.
https://www.sau.com.au/forums/topic/341956-creakkkk/#findComment-5517200
A creaking noise would generally be a stuffed bush - there is one at the end of each suspension arm. much as I hate suggesting it, pedders could help identify the stuffed bush (then get it fixed elsewhere :ermm:)
https://www.sau.com.au/forums/topic/341956-creakkkk/#findComment-5522651
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
    • I managed to get the foam will the original upholstery off in one piece, so will be an easy to re fit thankfully.
    • Then eventually someone in a Tiguan MK2 with an email toon and some random Alibaba pipes. (FWIW, I ran a 12.9s down the 1/4 in the wife's car)
    • Not much. It's barely more than an hour's labour. So that-ish plus a boot, clamp strap, some grease.   But, being an R32 GTR, when it is up in the air and the driveshaft is out, about $9k worth of other problems will become visible.
    • Yes, as above. The welding is an easy enough job. Proper reupholstering, perhaps less so. These, and pretty much all seats of the same era (and probably still) rely on molded foam parts to make the shapes. That foam is the yellow detritus visible in the photos. And it is difficult to replicate. I didn't want the pain, so went aftermarket seats instead. But for "saving a classic".... it's probably worth the kidney and left nut that a trimmer will want to redo them.
