honda civic 1994 manual low k's
great little car really cheap on fuel but still abit of power because of vti engine
never had a problem with it comes with rego and roadyworth
big sound system can be taking out if it not your thing
only selling because i want a dual cab for work so may trade if you have one
any questions call me on 0419492031
ebay link for pics
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=STRK:MESELX:IT
Edited by ceffydrifter
https://www.sau.com.au/forums/topic/341957-honda-civic-1994/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
