hey guys,
I am thinking about putting a POD on my R33 NA, I seen a K & N one at autobarn the otherday that I might pick up. I want to improve airflow and hopefully HP a bit, what you guys suggest POD wise? I heard K & N have good airflow and trap a fair bit of shit....give me your opinions on them..
FYI: http://www.gatty.net/car/ <<-- Pics of my car - it's 100% stock and was imported december last year (different rims obviously)
https://www.sau.com.au/forums/topic/34196-pod-filter-r33-stock/
Guest RedLineGTR
You have two options:
1. With your Stock box get a K&N high flow panel filter (many companys make them too)
2. Remove your stockairbox and install a pod filter, but with that u should make a Cold air partition (CAI) to stop the enigine heat getting to the pod and not making any preformance gain just sucking up the air.
K&N filters are good and are very easy to clean thats why alot of people choose them.
Check the Search Button there have been alot of threads about the samething and they have been overed in depth so they are quite a good read. My 2 Cents, Cheers Rob
hey mate,
I personally would go against a pod, as if a pig feels like defecting you they have grounds for it. I just grabbed just a new k&n panel filter for $95, didn't see any real performance increase but fuel consumption did drop a little. That's just my 2 cents :wave:
Sully
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
