hi people
i've got an r33 sreise II with planned 400rwkw.
its got a stand diff now but i am planing to run it down the quater with full drag slicks with the proposed power.
my question is will the standard diff survive (my guess is no)
and if it doesn't what is the better option, r33 gtr diff, hubs and shafts or pull the diff housing apart and put a minispool in it (locker)
thanks
https://www.sau.com.au/forums/topic/341968-lock-or-not-to-lock/
The stock diff is quite capable, If anything Locking a diff (i.e. welding the internals) can cause weak points in the diff as the welds are never as strong as the components and more often then not under heavy loads the welds often crack.
400rwkw I would stay with the standard diff and say go to a two-way or something if your going to be using it as a track car.
If your spending enough money on the car to make 400rwkw it's kind of silly to go the cheap way if you choose to modify the diff.
by stock i mean non shimmed, and not a clutch activated aftermarket 2 way...
stock = stock, not stock + bitz :)
I understand what you mean by stock, what I said was that if you were to upgrade the diff for better handling in corners like track work etc... you'd go with a 2-way
  • 1 month later...
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
