Hey guys, just got myself a '97 C34 S1 RSfour, came with an SAFCII, airflow lines have been taken back to stock, but the unit is still wired in.
On start up, it displays as per the first attached pic. After pressing the center button (I.E. trying to get to the menu), is displays as per the second pic.
Anyone got any ideas - I think the unit is cactus, but you never know.
Cheers
https://www.sau.com.au/forums/topic/341978-weird-safcii-fault/
start by checking all your wiring, i may be possible you disturbed a bad connection.
-there will be a plug that links the display to the ecu loom, check that is plugged in properly.
-another thing, the SAFC has 2 grounding wires, if one of those have come off or they are spliced in the wrong way around it will cause issues. from memory there is a brown wire and a black wire, they both need to be spliced into the one ecu ground wire and the brown one (i think) needs to be closest to the ecu with the black about 50mm further down the line. do you have the wiring diagrams for the SAFC to check i have the colours the right way around lol?
Gone through all the wiring, re did all the connections by soldering (rather than the shitty little splice crimps they provide).
As I was going through it, the ground wires were connected the wrong way around (brown is meant to be closest to the ECU, but black was), I fixed this, but still no joy.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
