heya guys i thought i might start myself a little thread detailing my work on my gtr. I bought it in feb this year and well i love it but it defiantly has been a pain lol. I bought it cheap and i know it had a few problems but i am fixing them all slowly. It started in my possession looking like this.
Uploaded with ImageShack.us
The mods on the car where
Built 26 with cp pistons eagle rods, n1 pumps, standard head and cams ect it was basically a freshen up rebuild with a new crank after a oil pump failure, high flowed turbos and a cat back exhaust power fc computer and it was producing 240 kw
It also had billstein coil overs and that was about it.
It needed afair bit of work when i got it for rego. Needed 4 new tyres, front upper control arm bushes, tyre rod ends on the rear, and acouple of oil leaks fixed up. I decided on getting a new set of wheels for the old gurl when i got the tyres and it took me a good couple of months to find them ones i wanted. I would have loved to go for a set of volk gt-c's but wheel i wasnt paying $3000 for a set of wheels without rubber. I settled for a set of Lenso DR1's which i thought looked tuff as and where one of the few wheels with the offset to suit the gtr. Next problem arrised well who supplied them well back in apirl no one seemed to be supplying the wheels and i found one place drift garage in sydney where like the only people that where bring them in. So i ordered them in and picked them up for $1300 for 18*9 with a + 15 offset i went for the 9 inch wide because i thought at the time 10 inch wide rims all round would be abit over the top. Than it was off to tempe tyres to get some rubber for it and i settled on a set of kumo ku31's. So all up the package sett me back alittle over $2000 which i was pretty happy about and this is how they look now.
As money was a little bit of a issue well lets face it i was being a tight ass i chose to go and get a sett of camber adjustable arms all round for the gtr and i end up using the jjr ones from just jap which seem to have done the job pretty well. I am not tracking the car atm so for street they should be fine for now.
Also when i picked the car up i knew that the gearbox had the typical 4th and 5th sincro problem so i picked myself up a second hand box and transfer at the right price. All was going well for about 2 months and it all went pear shaped as gtr owns would know it seems. Pulled up to work one day and when i was reversing into the car spot i knowticed a heap of whitish smoke blowing pasted the front and well i didn't know what to think at that stage. I keeped abit of a eye on it and well it just got worse and worse, I original thought it was turbo as the catch can had no oil coming through it but after racking my brain for weeks i took it into hunter and thoams automotive in newcastle he confirmed the worst this was about 3 months ago now.
So yeah the time came to search for a place to do a engine rebuild as i was not game to tempt fate and do it myself risking so much money. I have built quite a few stock cars falcons, and commodores but not a 26. I spoke to crd and a few other people and they where looking like the best bet with a exchange motor with the following
- Nitto 20 thou over pistons
- Nitto H beam rods
- Blue printed and balanced block and crank
- Nitto hi volume pump
- Nitto head gasket
- Tomei type b pon cams
- Gasket kit and ect
For $9000 exchange if my block was ok.
I was just about to go through with this and i finaly got ahold of Paul from Red R racing. Thank Christ i did, So than came the fun part of ripping out the motor as i did it myself and i gave it to paul to build. Here is some photos from the engine removal and stripping.
https://www.sau.com.au/forums/topic/342008-my-gtr-build/
When i droped it off to paul it was really ment to be a basic rebuild to get me going again but that soon changed as everything does. I ended up deciding and ending up with over a 4 or 5 week period.
reuse my CP 40 over pistons and eagle rods however my rods studs where resized
Tomei type b pon cams and valve springs and a pair of adjustable cam gears
Hks hi volume oil pump
Hks 1000cc injectors
Jim berry clutch
Rb30 flywheel as mine is time bomb to happen (stress fractures)
crank collar
Oil restrictor
Ross 1000hp 25 % over driven harmonic balancer
hi volume sump
A pair of 2860-5's which are on there way soon
Acl bearings and new rings ect
Nitto head gasket i believe
Gates timing belt and new tensioners ect
New Nissan water pump and all the other borning but necessary parts
The block ended up been to far over bored and had bad scoring so it was used as a boat ancher. The hunt was on for a new block it came in a form of a early series's block that had a oil pump failure with a standard bore it appeared to all good till paul measured up the crank tunnel and found it was out of alignment bugger, however paul saved me looking for another block and we did a trade as he could use my block.
Pretty much thats where we stand atm, the block is coming back from the machine shop this week and it can be reassembled.
https://www.sau.com.au/forums/topic/342008-my-gtr-build/#findComment-5519274
As far as the cosmetic side of things are concerned the engine bay and parts where beyond flithy for a 60 000 km old motor or it wasnt cleaned correctly when the last rebuild. Any how with the engine nearing completion it was time to get a move on with cleaning up the engine parts for the fitment of the new motor. Like painting the throttle bodies and thermostat housing and ect
as you can see a huge improvement i will be getting the linkages and ect re-zink coated to make them look new again also
You get the idea pretty much most things will be repainted and with the engine covers they are going wrinkle coated black like this and me inlet manifold will be done the same i was also maybe getting the twin turbo compressor pipes done to but i will see how it looks when it is back together it can be always done latter
With the engine bay i have decided to paint it white from the chassis rails up because well it is just beyond discussing. By all means this will be not a perfect job and i am not a professional painter by any means well actually this will be my first with a proper spray gun lol it will be the same colour as the car white to clean the engine bay up and make it look like it has been well looked after and clean not the way it is now. No point seeing my house deposit go into a dirty home. Here are some pics over the last 2 nights of work
How it looked just after the motor came out
Most of the engine bay has been cleared out to paint, i will be removing the guards and tucking the wiring in behind them and than start preping for the under coat. I also removed my front bar as i will be removing the intercooler to get it cleaned and pressure tested as it had alot of oil go through it was well as the piping here is acouple of pics just before we locked up tonight
I think it is time to call it a night there will be more work done tomorrow where the degreasing again for the 3rd time lol prep work and sanding will begin and the removal of the intercooler.
https://www.sau.com.au/forums/topic/342008-my-gtr-build/#findComment-5519345
Quick update picked up my pair of r34 gtr v-spec dump pipes thanks barbsgtr and motor should be completed in the next week or so, so paul says hopefully the car will be sent off to get the engine bay painted next week weather permitting i still have to remove the last bits of wiring.
https://www.sau.com.au/forums/topic/342008-my-gtr-build/#findComment-5526432
quick update block is back from machining just waiting on the crank now and it can start going back together. I also picked up a oil filter relocation kit and a hose kit. I should have a short motor by the end of next week which i am cheering about
https://www.sau.com.au/forums/topic/342008-my-gtr-build/#findComment-5537130
Engine bay is finished just waiting for the paint to dry and i will start refitting the wiring harnesses back in and stuff. By then the motor will be ready to drop in starting to get excited.
https://www.sau.com.au/forums/topic/342008-my-gtr-build/#findComment-5557828
engine bay is reassembled today thanks to my mate joshy for giving me a hand its all starting to come together hopefully can drop the motor in this weekend coming photos up tomorrow
https://www.sau.com.au/forums/topic/342008-my-gtr-build/#findComment-5568633
  • 4 months later...
Well its been a long time since i last updated this. All i can say it has been a character building process. With alot of delays and problems but firstly i have to say a huge thank you to paul at red r he truly went above and beyond that was required we spent a few very late nights getting this car back together. The end result is atm 320awkw. With drama's on the dyno we just ran out of time to tune it propley to its full potential. Saying that the power difference to what it was with the old motor and this one there is no compassion and there isnt a huge difference in lag time. All seemed to be going ok however a oil leak has raised its ugly head around the turbo oil lines which all i can say about that is FML. But i guess it is one of those little tests that life throws at you ey. So where it stands at the moment is :
  • Fix the oil leak
  • Fix a dead wheel bearing
  • Get the muffler made up its insanely loud but awesome lol
  • Bigger front mount
  • New O2 sensors
  • Get another tune
  • Get the body work done
  • And finaly replace all the disc rotors and pads
So yeah there is abit more to do but atm i got to tell myself it is back on the road and is drivable and it is a hole heap of fun to drive. I will up load some photos of the motor and ect this weekend
https://www.sau.com.au/forums/topic/342008-my-gtr-build/#findComment-5767798
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
