the front thermo fan is easy, $35 replacement 12" fan from ebay.
Ok tracked my problem to the thermal fan Passenger side. If you apply power as per manual (Both Zed and G35 Manuals) nothing hapens. If brave enough to give it a push it starts slowly on it's own runs for a while then stops again.
I have no idea what the issue is with the fan motor but it is stuffed. Drivers side works.
Now the questions ....I want to go as close to genuine as possible :
1. can you buy just the fan motor or do you need a complete dual assembly?
2. Is the Zed dual fan assy a straight swap for 2003 coupe.
3. Is the G35 dual fan assy suitable as they are a $100 or so plus post.
4. What price at a local dealership? As it appears you have to remove radiator as well with all those issues.
g
hey if anyone is after a radiator for a manual V35 I'm selling one cheep.
I may be out of line advertising here sorry....doesn't seem to be a V35 only advertising section
http://www.skylinesaustralia.com/forums/V3...;hl=v35+skyline
    • You would probably do a lot better in a claims process then most people. When I called the insurance company, they were surprised I read the pds because according to them almost no one does lol.
    • Yeah it should be, but I wouldn't be surprised if the insurance company tries to pull some argument out of their ass to avoid paying you out.
    • On some cars like MR2 Turbos they're notorious for not letting the wastegate open far enough to avoid overboost, especially certain cheap downpipes. If adjusting "percentage cycle" fixes it then it's just an electronic control issue, not a hardware one.
    • Same.  It's depressing to say this but the skyline can go months on the charger between drives.
    • I often leave mine connected weeks at a time. The main one I use is the old model of this, it has 2 important features - choose battery chemistry other than lead acid (most of mine are AGM) - power supply mode which you can use to try and recover dead flat batteries as "smart" chargers often don't recognise a dead flat battery is connected https://www.projecta.com.au/products/IC10/intellicharge-10a-bat-chgr The Ctek I  use was meant to have a battery test mode as well but it doesn't work 100% of the time so I am pissed at them. The distributor did everything possible to make warranty and support difficult so I'll stay away in future. The main thing with a "trickle" charger is it has multi stage programs, ie once the battery is full it turns the current right down to just maintain the charge....in the old days we just used real "trickle" chargers for that which had a maximum output of say 500mA which was safe to just leave connected to dumb old lead batteries.
