Just completed fitting the rb26 inlet manifold to our rb20det
The process was simple
Took just over 1 weekend to complete
*Cut rb20det runners
*Cut flanges off of rb26 manifold
*Aluminum weld them
*Weld aluminum flange to mount throttle body to the front of the plenum
*Cut and re-position water inlet
*Use porting tool to grind all uneven levels in welded runners (allot of porting is needed)
*Install throttle body
*Install stock rb26 aac valve setup
*Install manifold
*install fuel system
*Run new vacuum lines
*Rerun new intercooler piping
*Relocate bov
....thats about it
People said that i would of lost power
but all we got was good results :P
*The boost is building quicker
*The acceleration is way better now
*The throttle response is really great
*Less intercooler piping (about 4 feet or so less)
and no need to weld a flange to mount the aac valve, we used the stock rb26aac valave setup
* i really cant complaim about anything its a really great upgrade*
more pics will be posted soon
Someone asked me what was my supporting mods
its as follows
*Stock rb20 motor
*300zx 45v3 t3 turbo
*10-12 psi boost
*TurboXS boost controller
*Blitz bov
*Blitz LM 3" intercooler
*2.5 intercooler piping
*3" free flow stainless exaust
*Gear box rebuilt
*Upgraded ecu ( flashed\remapped )
*Fidanza 4.3 ceramic clutch kit
*NGK iridium spark plugs
*Walbro external fuel pump
*Runnin on castrol syntec
It will never work. Opps it does damn it .
Ha ha I always wonder why people pull the rb26 intake off and go to a single throttle body
You have done it the oppisite way and made more power good on you.
Would have been great to see an in gear rolling start 40-60km/h, 40-80km/h, 40-100km/h times and a dyno. Did you get the ecu re-flashed? If not then can there really be that much of a difference if the things airflow characteristics didnt change enough to require a tune....or if it did....do you know what is different about the tune in the way fo fuelling and ignition?
Surprised its made such an obvious difference with the turbo and power you are running because there have been various posts with some positive and some negative...lol woudl love to get my head around the reasons :P
But good work on getting it all together and running to your satisfaction
Edited by Roy
one you drive yout car every day and you do an upgrade you will fill the difference be it good or bad
The placebo effect can be very strong when you have put a lot of time and effort into a mod though.
Dyno is hard evidence, shame would have loved to have seen a before and after
I'm curious to know how you got the IAC/AAC system to work considering the log sits on top of the RB26's inner manifold section and has two steel tubes decending between two of the runners and connectiong up to the AAC/IAC chamber .
How ever you got it to work - well done .
A .
I'm curious to know how you got the IAC/AAC system to work considering the log sits on top of the RB26's inner manifold section and has two steel tubes decending between two of the runners and connectiong up to the .
A .
it was really easy
The 2 lines that run from the two steel tubes decending between the two RB26 runners to the AAC/IAC chamber are vacuum lines
so what i did was run the lines from the 2 metal hose fittings under the RB26 plenum to the AAC/IAC chamber
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
    • Cheers, yeah it was recently imported, is the actual Nissan not an Infiniti so will have to do some chasing around for parts.    Any ideas if the side skirts from a Q50 would fit on the 400r?
