Just completed fitting the rb26 inlet manifold to our rb20det
The process was simple
Took just over 1 weekend to complete
*Cut rb20det runners
*Cut flanges off of rb26 manifold
*Aluminum weld them
*Weld aluminum flange to mount throttle body to the front of the plenum
*Cut and re-position water inlet
*Use porting tool to grind all uneven levels in welded runners (allot of porting is needed)
*Install throttle body
*Install stock rb26 aac valve setup
*Install manifold
*install fuel system
*Run new vacuum lines
*Rerun new intercooler piping
*Relocate bov
....thats about it
People said that i would of lost power
but all we got was good results :P
*The boost is building quicker
*The acceleration is way better now
*The throttle response is really great
*Less intercooler piping (about 4 feet or so less)
and no need to weld a flange to mount the aac valve, we used the stock rb26aac valave setup
* i really cant complaim about anything its a really great upgrade*
more pics will be posted soon
Someone asked me what was my supporting mods
its as follows
*Stock rb20 motor
*300zx 45v3 t3 turbo
*10-12 psi boost
*TurboXS boost controller
*Blitz bov
*Blitz LM 3" intercooler
*2.5 intercooler piping
*3" free flow stainless exaust
*Gear box rebuilt
*Upgraded ecu ( flashed\remapped )
*Fidanza 4.3 ceramic clutch kit
*NGK iridium spark plugs
*Walbro external fuel pump
*Runnin on castrol syntec
Would have been great to see an in gear rolling start 40-60km/h, 40-80km/h, 40-100km/h times and a dyno. Did you get the ecu re-flashed? If not then can there really be that much of a difference if the things airflow characteristics didnt change enough to require a tune....or if it did....do you know what is different about the tune in the way fo fuelling and ignition?
Surprised its made such an obvious difference with the turbo and power you are running because there have been various posts with some positive and some negative...lol woudl love to get my head around the reasons :P
But good work on getting it all together and running to your satisfaction
Edited by Roy
one you drive yout car every day and you do an upgrade you will fill the difference be it good or bad
The placebo effect can be very strong when you have put a lot of time and effort into a mod though.
Dyno is hard evidence, shame would have loved to have seen a before and after
I'm curious to know how you got the IAC/AAC system to work considering the log sits on top of the RB26's inner manifold section and has two steel tubes decending between two of the runners and connectiong up to the AAC/IAC chamber .
How ever you got it to work - well done .
A .
I'm curious to know how you got the IAC/AAC system to work considering the log sits on top of the RB26's inner manifold section and has two steel tubes decending between two of the runners and connectiong up to the .
A .
it was really easy
The 2 lines that run from the two steel tubes decending between the two RB26 runners to the AAC/IAC chamber are vacuum lines
so what i did was run the lines from the 2 metal hose fittings under the RB26 plenum to the AAC/IAC chamber
    • It's definitely not firing order. But I think it should also be made clear that the output that gets fired is the one that corresponds to the input that was switched at the ECU. So you could scramble them up totally so that the numbers meant nothing, and so long as you had the inputs and outputs matched up, you'd be fine. The reason I make that point is that blanket statements about what it is supposed to be don't always hold out in a world where there's been 30 years for the wiring to have been stuffed with.
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
