Hi all I have a new engine combination being built up slowly and I need a car to put it in. For ease of engineering it has to be one of these cars, an R33 is a possibility but it would have to be the series one on the first or second production year.
EDIT: Probably the wrong forum but I would also consider a Porsche 924 or 944 shell if possible.
Contact me via PM or by email at [email protected].
Cheers.
Edited by R33_Dude
https://www.sau.com.au/forums/topic/342018-wtb-s13-r32-or-fc-rx7-shell/
Hi, I have a R32gtr shell Im seriously considering selling, all it needs is a motor and box, very good cond, registered, if ure interested pm me ure ure phone number, cheers Damo
Sorry mate a GTR will make it harder than what I want plus I wouldn't like to put the engine I have into a GTR it would just be wrong - well it already IS wrong almost no matter what car I put it in but in that case it would just be sacrilege. That said shoot me a PM with some relevant details (what is missing and so on) and how much you would want for it and I'll get back to you.
Hey Autumn I know about the RX but I will have to give it a miss. Did you get my texts? My phone has been in to Nokia twice this fortnight and its still playing up... Basically I have been resorting to email, facebook and PM contact with people. I would straight swap you for the soarer minus your rims, sound and whatever other bits you would want to even it up though. I'm pretty sure I have some steel rims that could go on temporarily.
nah i havn't got your texts lol ill have a think about it & get back to you bud
EDIT: if you give me 2k on top ill swap you the 7 & ill keep the wheels or if you want a shell ill pull the motor & box out & straight swap you?
Edited by Autumn_180
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
