I have a 1997 Series 1 RB25DET engine on my Stagea and since receiving the vehicle over 2 years ago have had a problem with the engine cutting out intermittently. Only seems to happen when the A/C is running and the accelerator is slightly feathered after idling (in slow moving traffic for instance). A couple of trips to the local mechanic have not resolved the problem so any assistance would be appreciated.
https://www.sau.com.au/forums/topic/342033-engine-cuts-out/
I would recommend you try cleaning out your idle control valve (at the back of the plenum) and also your air flow meter.
See if that fixes it, or at least rules them out.
https://www.sau.com.au/forums/topic/342033-engine-cuts-out/#findComment-5519129
No aftermarket BOV fitted? What's ur idle rpm in neutral with handbrake on and no a/c and then with a/c
Clean aac valve
Clean afm
Copper plugs at .8mm
Block intake pipe and pressurize intake system with bike pump and check for leaks
Check timing
Reset ecu
Report back.
https://www.sau.com.au/forums/topic/342033-engine-cuts-out/#findComment-5519295
In answer to questions, the engine doesn't stall when idling in neutral or in drive when stationary only when applying a small amount of revs when starting to move; engine rpm drops off suddenly when the power cuts out; no aftermarket BOV is fitted; idle rpm in neutral with handbrake and no a/c is 750rpm, with a/c on start up goes to 900rpm then drops to 800rpm.
Sunday is my only day off work so will try and do the checks suggested then.
https://www.sau.com.au/forums/topic/342033-engine-cuts-out/#findComment-5520021
Does sound like AFM or even TPS needing adjustment. See if you can borrow another AFM to rule that out.
https://www.sau.com.au/forums/topic/342033-engine-cuts-out/#findComment-5520322
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
